RevRico
RevRico UltimaDork
4/21/21 8:11 p.m.
Let's pretend you need to stock a new garage/shop with chemicals, starting with none.
Wd 40
Pb blaster
Qr electronics cleaner
Brake clean
Carb and choke
Starting fluid
Anti seize.
That's my list. Anything I'm missing?
I've decided since I work in both my garages, instead of running back and forth all the time, I should just stock them both, and rather than scrounge around for partial containers I just want to get all new for one of them.
BoxheadTim
BoxheadTim MegaDork
4/21/21 8:20 p.m.
Maybe brake grease (I like the CRC Ceramic stuff) to go with the brake cleaner?
Streetwiseguy
Streetwiseguy MegaDork
4/21/21 8:24 p.m.
You have no lubricants on the list.  Fluid Film.  Purple silicone brake grease.
Wd40 isn't a lubricant.
stanger_mussle
stanger_mussle UberDork
4/21/21 8:37 p.m.
RTV
Gasket maker (Grey Stuff?)
4/21/21 8:39 p.m.
Simple Green
Windex
Sil-Glyde
4/21/21 8:46 p.m.
Acetone, mineral spirits, denatured alcohol.
fasted58
fasted58 MegaDork
4/21/21 8:47 p.m.
Acetone
Zylol
Lacquer thinner
Purple cleaner or kero type cleaner
Dawn
Jay_W
Jay_W SuperDork
4/21/21 9:02 p.m.
 hand cleaner....
4/21/21 9:03 p.m.
Beer.
Actually, I almost never drink, I just wanted to be the first to say it.
travellering
travellering HalfDork
4/21/21 9:27 p.m.
Gasoline?
RevRico
RevRico UltimaDork
4/21/21 10:05 p.m.
Ahhh thread cutting fluid.
Streetwise, is White lithium in a can an ok lubricant?
captdownshift (Forum Supporter)
captdownshift (Forum Supporter) UltimaDork
4/21/21 10:25 p.m.
Deep creep. It's the last step before the torch comes out.
stuart in mn
stuart in mn MegaDork
4/21/21 10:28 p.m.
A can of general purpose grease, and also a can of wheel bearing grease.
Waxes, rubbing compounds, polishes, and cleaners of your choice.
Apexcarver
Apexcarver UltimaDork
4/21/21 10:43 p.m.
Loctites red and blue.
Dielectric grease
Dihydrogen monoxide
Evaporust
4/22/21 5:06 a.m.
CRC Freeze-Off is the E36 M3 & I use it on/for everything. It also smells really good.
John Welsh
John Welsh Mod Squad
4/22/21 6:51 a.m.
A couple of years back, we had a big discussion about anti seize.  I love the stuff I got from McMaster
As a rust belt dweller, I still stand behind what I wrote in that old thread...
The McMaster stuff is an actual joy to work with and as such I am very likely to use it.
That silver stuff is misery to work with so I would often avoid using it, even if I needed it.
wvumtnbkr
wvumtnbkr PowerDork
4/22/21 7:12 a.m.
Kroil instead of wd40 and pbblaster.
90BuickCentury
90BuickCentury Reader
4/23/21 6:33 a.m.
By garage chemicals, do you mean chemicals beside the obvious fluids that your car uses (Engine Oil, PS Fluid, R134a, etc)?
Degreaser.
Fuel stabilizer?
Cat litter/sawdust for spills.
Eye wash station with the small bottles of saline.
tester (Forum Supporter)
tester (Forum Supporter) Reader
4/23/21 7:05 a.m.
Motor oil in all the weights that you use.
ATF - ditto
Gear oil- ditto
Coolant compatible with your hoopties
WD40 for electronics
Dielectric grease
Heat transfer grease
PB or Kroil
Simple Green, degreaser, other cleaners of your choice.
Wheel bearing Grease
Wasp/bug spray
Brake clean
Throttle body/carb clean
alcohol, mineral spirits, paint thinner
RevRico
RevRico UltimaDork
4/23/21 7:07 a.m.
I've watched that GRM live like 6 times now, but I still haven't found a can to try out in real life. It really works as advertised?
BoxheadTim
BoxheadTim MegaDork
4/23/21 7:09 a.m.
I've just started using it on the BRZ - so far there isn't much that PB Blaster wouldn't have taken care of, so I can't tell if it's that much better, but it does seem to do the job well.
chandler
chandler UltimaDork
4/23/21 8:51 a.m.
Let me look in my garage....
ok, looks like you also need a hundred cans of partially used different spray paint
4/23/21 9:25 a.m.
I really do like it best out of all the penetrating lubes I've tried(which I think is all of them), plus I really do like the smell of it.
GIRTHQUAKE
GIRTHQUAKE Dork
4/23/21 2:42 p.m.
List so far from ProjectFarm on youtube:
  • Vibra-tite for blue loctite
  • Pro-seal for red loctite
  • CRC 6026 HD Corrosion inhibitor for underbody sealing- fluid film if it needs to be removed later
  • Loctite copper for anti-sieze, unless its on aluminum. Consider a nickel or aluminum base if it is.
  • Spray Nine for anti-mold.
  • 2+2 Gum cutter for anti-carbon (not legal in Cali, this stuff is legitimately carcinogenic.)
  • Penetrol or Schtchguard to protect patina.
  • Wanna protect bare metal? Harley guys swear by Gibbs spray oil, same with Cold War Motors.
Use the organic Walnut shell based hand cleaner- Gojo is crap, better for wood cleaning than hands.
Other needed things include:
  • Orange safety spray paint.
  • Simple Green for anti-grease. It's been tested to be the best degreaser under hot temps.
  • Alcohol
  • Mineral Spirits
  • Acetone
How many more do we want?
4/23/21 2:52 p.m.
Tim's thoughts on that very subject.
YmK1aJr28PDefIb27msrt6HVjNCu1XyqOGMxeAaiBKD2vvGum2xfCsIByHdynfXp
