jimbbski
jimbbski SuperDork
4/23/21 9:52 p.m.
One item not mentioned is an old candle. I've used it to free stuck nuts and bolts.  Heat up the fastener then rub the end of the candle on it,the wax will melt and seep into the joint. Then reheat. It does work.
M2Pilot
M2Pilot Dork
4/24/21 8:04 p.m.
k-y jelly.
For lubricating coolant hoses and such.
93gsxturbo
93gsxturbo SuperDork
4/25/21 9:04 a.m.
Off the top of my head going through my garage rack...
  • Paint
    • Satin black VHT Epoxy
    • Some bright colors, red, blue, green, etc
    • Maybe a can or 3 of primer if you like stuff to look good
  • Cleaners
    • Brake Clean
    • Carb Cleaner
    • Contact Cleaner
    • Purple Power
    • Simple Green
    • Car wash soap
    • Wheel cleaner
  • Lubricants
    • Engine oil, whatever you use in your car(s) get an extra gallon of it
    • Air tool oil
    • Trans fluid, a few quarts of whatever you use
    • Few quarts of gear oil
    • Boeshield
    • Wheel bearing grease, high temp stuff
    • Lithium Grease
    • Silicone Spray
    • Dielectric Grease
    • Antiseize
  • Penetrating oil
    • CRC Freeze Off
    • PB Blaster
  • Misc
    • Antifreeze, whatever your car uses.
    • Windshield washer fluid
    • CAIG De-Ox-It electronics cleaner
    • WD-40
    • Spray Detailer
    • 2 stroke oil
    • Bar and chain oil
    • Red loctite
    • Blue Loctite
    • Loctite activator
    • Gray RTV
    • Teflon pipe sealant
    • PVC primer
    • PVC glue
Brett_Murphy
Brett_Murphy MegaDork
4/25/21 2:34 p.m.
An eye flush kit.
Superglue
tWT2kH3YajWoFqcke5wXRRFktvXxGE7JYcyOcSqhpT6j0SHxFuFliPFeMHiLvpxz
