JoeyM
JoeyM SuperDork
6/14/11 11:34 a.m.
Most 1930s cars came with door hinges that stuck out beyond the door and body. I was thinking about using these cabinet hinges from Lowe's They're cheap, but they are not the right shape/size. (Too narrow and too long).
Would you use them, or find something else? What other cheap options can you think of?
wlkelley3
wlkelley3 Dork
6/14/11 11:44 a.m.
Don't think those will hold the weight of the door.
I'm sure there are hinges designed for what you're trying to do. At work and can't google it.
Or find a car with the type hinges you want and use those.
tuna55
tuna55 SuperDork
6/14/11 11:45 a.m.
I would worry about the ability to hold up to abuse. Perhaps find a specialty vendor that could get the right size/shape/durability options? Maybe some artisan type brands? Try mcmaster yet?
Good thought.
mrhappy
mrhappy Reader
6/14/11 11:48 a.m.
How about some off of a wrangler?
mad_machine
mad_machine SuperDork
6/14/11 11:57 a.m.
VW beetle? (AC)
aircooled
aircooled SuperDork
6/14/11 12:00 p.m.
Hmmm, what about the hinges off of the tail gate of a smaller truck? Ranger etc.
Might want to wander through a wrecking yard if you have one near by... you may look at the neighbors truck, but don't touch... I know how you are partial to things your neighbors leave outside.
Javelin
Javelin SuperDork
6/14/11 12:56 p.m.
You need to pick up a copy of Street Rodder magazine and start browsing the vendors. They still make all that kind of stuff, and most of it (the non-polished, non-billet stuff anyways) is actually really affordable.
Rob_Mopar
Rob_Mopar Dork
6/14/11 1:11 p.m.
mad_machine wrote: VW beetle? (AC)
That was my first thought.
cwh
cwh SuperDork
6/14/11 1:32 p.m.
Any skilled metal guy can make up any kind of hinge you want. Gate guys have to support a lot more weight than your doors, might have something laying around. I have made a large bunch of hinges, but not now.
ultraclyde
ultraclyde Reader
6/14/11 3:55 p.m.
Check out hinges at your local tractor Supply or similar farm implement store. They usually have some beefier stuff that might fot the bill.
Give me two friends, the contents of a Tractor Supply store and a Radio Shack, and a week - and I can put you on the moon. Okay, maybe 10 days.
ValuePack
ValuePack Dork
6/14/11 4:28 p.m.
This. Much more durable than anything you'll find at a home improvement place, and should be cheap and easy to find to boot.
ditchdigger
ditchdigger HalfDork
6/14/11 6:14 p.m.
Speedway motors budget door hinges to the rescue
http://www.speedwaymotors.com/Budget-Hinges,3402.html
JoeyM
JoeyM SuperDork
6/14/11 6:23 p.m.
Javelin wrote: You need to pick up a copy of Street Rodder magazine and start browsing the vendors. They still make all that kind of stuff, and most of it (the non-polished, non-billet stuff anyways) is actually really affordable.
I get Street Rodder (although I sometimes wonder why), and I know that SpeedwayMotors sells these: I also know that I was hoping to not spend $100+shipping.
Junkyard Jeep, VW or Truck parts sound like more of a challenge-friendly price. I headed out to the pick and pull after work, but got there too late to go into the yard....they did say that they have a Jeep on the premises, though. I may be heading out there again later this week.
mad_machine
6/14/11 7:35 p.m.
Jeep may be a good choice too.. though, I think those hinges are designed to come apart
JoeyM
JoeyM SuperDork
6/14/11 7:47 p.m.
I'll probably still visit the pick and pull, but I just went to TSC where I got this Now I need to use a band saw and welder to try to turn it into this
JoeyM
JoeyM SuperDork
6/15/11 5:32 a.m.
aircooled wrote: you may look at the neighbors truck, but don't touch... I know how you are partial to things your neighbors leave outside.
JoeyM
JoeyM SuperDork
6/15/11 5:33 a.m.
Well, here goes nothing...
JoeyM
JoeyM SuperDork
6/15/11 8:10 p.m.
Before (left) and After (right) I'll call that a proof of concept....I rushed, got sloppy, and it didn't turn out well enough to use, but I still think the idea has potential. The hinge is made from the center of the old hinge. The outer portion (washer, flat rod, nut) is supposed to be the retainer on the hinge. Again, here's the real datsun hinge for comparison:
orphancars
orphancars Reader
6/15/11 9:12 p.m.
the classifieds section @ www.thesamba.com should be your friend here..............your pic looks a lot like a VW Type 1 hinge.........
SVreX
SVreX SuperDork
6/15/11 9:38 p.m.
Your "original" picture shows a 3 knuckle hinge. The Speedway Motors version is a 5 knuckle hinge.
The cabinet hinge will never work. Waaay too lightweight. Your fabricated one is closer to what you will need, although strap hinges are notoriously sloppy and made of very cheap components- they rust easily.
Don't forget the offset. The center of the hinge pin is set away from the body of the car so the door can open without the curve of the door or body colliding.
Picture the entire weight of the door hanging on the hinge when it is 90* to the car. With a kid hanging on it. Weak components or sloppy hinge pins won't work. You will also need good weldability (strap hinges might be questionable). That's why the Speedway Motors version is beefed up.
SVreX
SVreX SuperDork
6/15/11 9:38 p.m.
The orphan is right about VW hinges.
JoeyM
JoeyM SuperDork
6/16/11 7:16 p.m.
SVreX wrote: although strap hinges are notoriously sloppy and made of very cheap components- they rust easily.
My second attempt came out more sloppy than the original strap hinge. It's WAY better than the last one that I built, though. I think a nylon washer would be enough to get rid of the play and fix it up nicely.
Definitely true for when I set it up for the street. This might work for a challenge-budget situation.
oldtin
oldtin Dork
6/16/11 7:38 p.m.
Early ford broncos - last I looked were about $18/hinge or rebuild kits are something like 7-8 bucks/hinge
AquaHusky
AquaHusky Reader
6/16/11 8:51 p.m.
I was thinking hinges off old trucks. Or even the old 70s vans with the split side doors. Don't early Suburbans have that style hinge as well. Also, Aerostar vans with the liftgate rear have them.
SVreX
SVreX SuperDork
6/16/11 10:13 p.m.
Looks like there are an awful lot of options on fleabay:
529 options
lyvMOx5ghajRE33BJx5pOOTc9CwtX5oDDx31IO4ZlXwIS4cbFMyy59a9adkl9r1E
