tuna55
tuna55 MegaDork
10/7/19 7:38 a.m.
Scenario #1: The concrete driveway has a narrow strip of garden between it and the retaining wall. I wish to put something as edging between the driveway and the garden to prevent the ground cover from spilling out.
Scenario #2: Brick patio bordering backyard. We need to add a french drain, but also need to prevent grass growing over the brick.
Scenario #3: We want to make a walkway through the middle of the backyard, mostly rock. I need to separate the path from the weeds (lawn). This edging needs to be low enough for the mower to run over, even if I have to shut the blades off.
So, I need lots of edging, and everything I find in a home improvement store is utter crap.
What do people use?
Hasbro
Hasbro SuperDork
10/7/19 11:28 a.m.
4"x8' steel or make your own concrete with rebar.
volvoclearinghouse
volvoclearinghouse PowerDork
10/7/19 11:47 a.m.
Big Box store is crap. Maybe ask some landscapers and find out what the "pros" use.
hobiercr
hobiercr SuperDork
10/7/19 11:53 a.m.
When we redid our front lawn landscaping the nursery we used carried a heavier aluminum edging that was not available at Lowdepot.
STM317
STM317 UltraDork
10/7/19 11:55 a.m.
I use this metal edging, but I also got it at a big box store, so maybe it's crap? For straight lines you could use something thicker, but that stuff won't do bends or radii very easily. I've got a mix of gentle curves, hand formed permanent bends and straight sections with 90 degree corners and have been happy with it thus far. I've got 2 seasons on mine now where I run the string trimmer along it about every 5-7 days between March and Nov and haven't damaged the powder coat. And while I wouldn't want to make a habit out of it, I've found that I can drive into/over it with my 1500lb mower and it doesn't bend or damage the finish.
hobiercr
hobiercr SuperDork
10/7/19 12:18 p.m.
Metal Edging sounds like a great band name. "We'll almost take you there!"
ePf6QntZ0iYuBKanTeskrcVTD78RIQQExNUe5GK1I1PI3rVrNdJ2uG7DK9D1hZug
