well, with the impending shutoff of analog tv signals (garage tv, etc) I decided to go the OTA HDTV way.
found a way to make an antenna that pulls in 25 HDTV digital channels.
get this....
Using metal coat hangers and a piece of 2 x 6.
I'm VERY impressed. zero cost out of pocket just using things around the house.
Gonna cancel the Satellite service I think. thats $25 I don't need to s pend. My OTA picture is cleaner than what the satellite gives me.
couple links if your interested. I was sceptical, but it does work.
http://www.youtube.com/watch?v=EWQhlmJTMzw
http://www.lumenlab.com/forums/index.php?showforum=72
I have an issue of Popular Science from the mid 1950s that has plans for essentially the same antenna. The same article had plans for another antenna made from triangles of tinfoil taped to a piece of cardboard; I built one of those and it worked pretty well too.
Getting digital TV over the air will generally result in a better picture than cable or dish, although of course you'll only get local channels. On the other hand, the local stations may have more digital content available - for instance my local PBS channel has three different digital channels.
While I'd love to ditch the evil cable, the Wife watches way too much cable-only stuff and I would never be able to figure out a wife-friendly way to DVR the OTA content anyway. I have thought about throwing together an antenna to see if there's anything I can get OTA that I'm missing out on with cable, but I'm too lazy at the moment.
All I watch are cable channels, so while this is a novel idea and I'd love to do it when I get my RV, I don't think this will be happening at home. I'd die without my discovery channels, cartoon network and Spongebob . . . I MEAN . . . uhhh . . .SPORTSCENTER! DUT DUT DUT . . .DUT DUT DUT!
-Dave
pigeon, the answer is uTorrent and an RSS feed from eztv.it. The best part is that then you get Top Gear too :)
Keith:
How do you do that?
Fewer abbreviations please. I'm computer illiterate, and while this thread is interesting to me, it's already looking like a memo from the military.
I can't stream the video for the antenna, can someone transcribe this and print it out.
I need a better solution to my poor amplified antennas.
And websense blocks Lumenlab!!!
I loathe my boss right now.
Can someone copy and paste pretty please?
Here is one I want to try, haven't had time yet...
Gray-Hoverman UHF Antenna http://www.digitalhome.ca/ota/superantenna/
I was absolutely shocked. I ditched DirecTV and a buddy of mine gave me some of those rabbit ears from 1979. All of a sudden, I have 8 channels in HD, and that's with the antenna hanging behind a cabinet.
Its very plausible. if cheapo rabbit ears from Radio Shack (Archer brand) can pull in HD, coat hangers can do the same.
JmfnB wrote: And websense blocks Lumenlab!!! I loathe my boss right now. Can someone copy and paste pretty please?
Here ya go:
Lumenlab said:
I thought that I'd pass this along for anyone looking to buy an OTA HD antenna. I purchased a DB2 antenna a while back, and for $40 + S/H (@ the time) it looked exceedingly simple. So I took some measurements and built one from stuff that I found around my house.
Materials: (what I used) 1 piece of card board cut to 18" x 12" 1 sheet of tin foil also cut to 18" x 12" 1 strip of wood 1" x 1" x 12" 2 blocks of wood. Each cut about 2" off of the end of a 2x4 (1 1/2" x 3 1/2" x 2") 2 wire hangers 6 screws (I used 2") 4 medium sized washers (don't recall the exact size) 2 smaller washers 1 UHF matching transformer (or balun) scotch tape hot glue stick (optional)
Tools: Screw driver Pliers (heafty enough to help bend the hanger wire) Dykes/wire cutters (heafty enough to cut the hanger wire) Hot glue gun (optional) Sand paper, wire brush, or a file.
Assembly:
1: Lay the tin foil over the cardboard and use the scotch tape to kepp it in place. Then draw a line down the center of the front and back of the reflector along the 12" width.
2: Lay the 12" strip of wood on the center line on the back side (not the foil side) of the reflector and temporarily secure it with a couple of dabs of hot glue.
3: The other two blocks of wood will be attatched to the front as in the following drawing.
4: Insert screws into the blocks of wood attatched to the front of the reflector. Each block receives two screws and two medium washers. The screws on one of the blocks will also have the smaller washers ontop of the medium ones. Do not tighten the screws down all the way.
5: Straighten out the two wire hangers. You want four pieces of wire each 14" in length, and two pieces 6 1/2" to 7" in length. (I will now refer to the wire as rods)
6: Bend the four 14" rods in the middle to about 24 degrees or until the two ends are about 3" apart.
7: Using the sand paper or whatever you have, clean the coating off of the rods at the points circled in the drawing (above). While you are at it make sure that your washers are capable of making a clean contact with the rods.
8: Place the two straight rods on the blocks as shown. (EDIT: The rods in this picture are shown to be on the "inside" of the screws. But they should be placed on the other sides.)
9: Place the bent rods on the blocks as shown, and tighten the screws. Only lighly tightening the screws with the small washers. (EDIT: As in the edit above, the rods in the top part of this picture are placed incorrectly. However they are correct in the drawing in the lower part of the picture.)
10: Connect the UHF matching transformer to the antenna using the screws with two washers each and tighten to secure. (EDIT: Again, rods bad, I suck.)
COMPLETE!
In my un-scientific tests this antenna seems to hold it's own against the DB2 as an indoor antenna . In outdoor tests it performed almost as well as the DB2. Although I wouldn't use this one outdoors, being card board and having a solid reflector. One good gust of wind and it'll fly away. But there is no reason why you can't build one with higher quality materials to be used outside. Like a cooling rack for a reflector so that it doesn't catch the wind.
I'm also a techamoron (pronounced tek-a-ma-ron ;)).
So is this thread and are these instructions saying that you can build this and use an old TV without buying the digital stuff that'll be required in February...or is this for TVs that are already digital-ready?
Thanks...
Clem "too cheap for cable" Sparks
Grtechguy wrote: You'll need a convertor box or an HDTV ready tv
OK then...I'm out.
Thanks though!
Clem
Which is about $9 more than I'm willing to spend at this point. I guess come February, I'll likely be singing a different tune ;). My 6" tv is pretty much only usefull for watching DVDs and the occasional race anyway.
Clem
I made the one in the first video but I can't get good reception with it. I have tried buying antennas before but they never worked well either, I just don't get good reception here I guess.
SVreX wrote: Keith: How do you do that? Fewer abbreviations please. I'm computer illiterate, and while this thread is interesting to me, it's already looking like a memo from the military.
Had to wait until I got home, but here you go.
You will also need this feed: http://feeds.feedburner.com/finalgeartorrents. Set up a filter to suck down anything with Top?Gear* in it. Voila, immediate delivery of Top Gear.
Oh man, I HAVE to get my full-time torrent box set up now! I've got a 320GB HDD and a 1TB SCSI drive array ready to go in! I think I'll need to get a USB-SCSI enclosure with RAID support and a USB2.0 PCI adapter though...it's a small Pentium 3 box, I'm trying to keep the power usage down.
GeekI'm just setting up a mirrored two-disc setup for network storage now, nice and cheap.
I'm not sure what time Top Gear plays in the UK on Sunday, but I usually watch the episode on Sunday night in Colorado. It's magic! Rallytorrents.com has an RSS feed now so you can get next-day delivery of the WRC.
