Somebeach (Forum Supporter)
Somebeach (Forum Supporter) Reader
12/3/20 7:53 a.m.
Not sure where to put this. But any guess on value for a 74 Ford 302 and a 72 C4 transmission?
I am thinking about buying a car, engine and transmission can come part of the package or not. So just trying to see if I want to make an offer on whole deal or just the roller.
jfryjfry (FS)
jfryjfry (FS) Dork
12/3/20 7:59 a.m.
I assume old, used, unknown condition but "ran when pulled?"
Also assuming for a car and not a truck/bronco...
$300-800, depending on how complete
There is a combo local to me for $450. I'd offer $300 or so.
I wouldn't go any more than that unless I could hear it run and see it move under it's own power.
NOHOME MegaDork
12/3/20 8:10 a.m.
C4 gearboxes are getting hard to get because the cores are running out. Tried to get one for the Molvo when the AOD did not pan out.
jimbbski
jimbbski SuperDork
12/3/20 2:02 p.m.
Yeah, '74 model year 302's were not much power wise. Low compression and flat cams.  IF the bottom end is sound then a simple cam swap and either later 5.0L heads (GT40 or GT40P) or aftermarket ones will boost power quite a bit.
Strizzo
Strizzo PowerDork
12/3/20 3:28 p.m.
In reply to Somebeach (Forum Supporter) :
I just sold a 66 mustang C4 with dipstick tube, crossmember, converter and driveshaft for $250.
Was pulled ten years ago for an aod and sat in storage so the assumption was it could need a rebuild but it probably is gtg.
Streetwiseguy
Streetwiseguy MegaDork
12/3/20 3:40 p.m.
Cast iron is about $25 per ton just now, Clean aluminum quite a bit more.  If you take it apart, melt the steel inserts out of the aluminum castings, you might get upwards of $50.
Mr_Asa
Mr_Asa SuperDork
12/3/20 3:51 p.m.
I can find roller cam 302s in the junkyard still, and they charge $150 +$50 for a core.  I wouldn't pay more than that.
C4s are rarer, though.
dropstep
dropstep UberDork
12/3/20 6:49 p.m.
C4's are around 250 for a core in my area. If anyone wants a core I'll cut you a deal to get it out of my garage! 302's seem to be between 200-500 for a might run.
this spring when I did my swap I spent 400 for a wrong c4 and an engine that hadn't ran in 25 years. Then spent 300 for a c4 that turned out to be a steal at that price.
CJ (FS)
CJ (FS) HalfDork
12/4/20 11:26 a.m.
ERROR.  Wrong topic
iX34AWxg428uqOaQ90mPGzZ0nEGj7ENPWX8tS96iPAY9ELrsVLQUrRziQwt5V5Ez
