tuna55
tuna55 MegaDork
7/17/18 9:15 a.m.
I want a connector for this guy. I bought a generic connector but it was too deep and could not reach in.  Is there a connector that deals with this deeper housing?
lnlogauge
lnlogauge Reader
7/17/18 10:48 a.m.
congrats to seagate for making a sata connector proprietary.  It's deeper than any typical connector I've ever seen. As far as I know, deeper cables don't exist.
https://memoryclearance.com/stae109-seagate-stae109-usb-cable-adapter-1-50-ft-proprietary-connector-usb.html?gclid=CjwKCAjwp7baBRBIEiwAPtjwxECiK2HkcEMnev5jYCfBT-ZAByCEh9vSGWEc8ktxkPOdSMSaldGWYxoC4rYQAvD_BwE
Your best bet is to move the hard drive to a external case that doesn't suck.
dculberson
dculberson UltimaDork
7/17/18 10:53 a.m.
tuna55
tuna55 MegaDork
7/17/18 1:04 p.m.
In reply to dculberson :
Thanks dude, I'll try it!
Stefan
Stefan MegaDork
7/17/18 1:45 p.m.
Worth a shot until the drive or the controller dies.
Good luck!
tuna55
tuna55 MegaDork
8/20/18 1:22 p.m.
Alright, so I finally got around to buying it, and it plugs in, but no chooch. This thing only has a USB cable, no separate power. Am I missing some intelligence here?
1988RedT2
1988RedT2 UltimaDork
8/21/18 7:15 p.m.
USB should provide for both power and data transfer.  Some USB ports may be unable to provide enough current to run the drive?  If you have it plugged into a front panel USB port, try one on the back panel.  Bad adapter?  Bad drive?
lnlogauge
lnlogauge Reader
8/22/18 9:07 a.m.
5v at 1.5amps is not enough to power a 3.5in  hard drive. The cable you bought works for a go flex, which is a laptop hard drive external case.
The base of that FreeAgent had a 12v power connector supplying the power. I've think you've proven there's no way around owning that base. External hard drive cases are cheap.
oWsEgCfksqSd0lmWkmzlpqEmfeRcehpkQGm4dV8LkJHSao4jlEt8JPtRG3bHm80X
