No Time
No Time SuperDork
8/22/21 5:15 p.m.
The thread about smokers reminded me that I need to find a good temp probe in the next week or two. We are having folks over for Rosh Hashanah and smoked brisket is on the menu.
The last time I smoke brisket I found that the probe on the grill read about 10 degrees different than my instant read that I normally use to check internal temps for grilling. As a result I think I waiting a bit too long for wrapping to get through the stall and ended up with the flat being a bit dry, but the point was perfect. I only had one probe, and that was in the point cut.
I'd like to find one that has at least 2 probes and some alerts to notify my when a target temp is reached. BT/WiFi would be great so I can be doing other things around the house and get notified if it reaches the target temp.
Let me know what your favorite temp probe is for use with smokers and grills.
Thanks!
RossD
RossD MegaDork
8/22/21 5:19 p.m.
I like this one:
https://www.amazon.com/dp/B017613C3C/ref=cm_sw_r_cp_apa_glt_fabc_99M2K8J939WDHB4RSSGD
It doesnt have your options however.
minivan_racer
minivan_racer UberDork
8/22/21 5:37 p.m.
All I know is that the angle of the dangle is directly proportional to the heat of the meat.
stukndapast
stukndapast Reader
8/22/21 5:44 p.m.
I went through several electronic thermometers before I found Thermoworks.  Excellent quality stuff.  Look and buy directly on their site, not Amazon.  I'm sure they will have something that will work for you.  https://www.thermoworks.com/
RevRico
RevRico UltimaDork
8/22/21 5:45 p.m.
I have several no name brand digitals all within about 3 degrees of each other. When I'm really pushing things though, I have a Maverick with 2 probes built in. I prefer multiple cheaper ones to the maverick though.
11GTCS
11GTCS Dork
8/22/21 5:52 p.m.
Brisket is one of the few things I haven’t had luck with in the smoker so far, it’s not “set and forget” like a lot of other things I’ve done.  A good thermometer is important but checking frequently is as well.
SbRPt9db9YwH4514y6Q9FgKwjdWEcYLGGnk0NkXX4ABnV2NlfsTp0USmGwwPt6W0
