Play by play of where I am now:
- Go to make a sandwich and I grab a beer
- Feels oddly not-cold
- Take my cooking thermometer and stick it in the fridge for a min. 64 degrees
- Pull fridge away from wall 7 unplug.
- Take off rear panel and front intake panel. This is a fridge with a bottom freezer and the coils are below the freezer.
- Coils are absolutely caked with dust. Obviously this is a problem.
- Got a vacuum, paintbrush, and dragged my compressor & air nozzle upstairs to clean it out the best I can (its damn near impossible to reach the center of the coils). Its not 100%, but probably 98% clean now.
- Plug it back in. I can hear a fan running inside the freezer, but nothing related to the compressor is running.
- Unplug again.
- Remove overload relay. Shake it (internet recommended this) but it doesn't sound like anything inside it has failed. Its not 100% solid, but it sounds like a loose-fitting metal contact does on other stuff - like european/us A/C adapters.
- Put it back together and plug it in.
- Still just have the freezer fan running, but no compressor kicking on.
- The compressor feels warm to the touch but not hot.
What's my next step?
we're dealing with a fridge problem too. freezer is cold but not freezing cold, fridge side is cool but not cold enough. it's over 10 years old so it's out of warranty. i dunno anything about fixing it so we either hope a repairman will call us back or we check for used ones on craigslist.
it sucks.
jgrewe
Reader
7/12/20 10:36 p.m.
Does it have a timer for the defrost? If it does find it and you should be able to turn it manually to see if it is stuck in the defrost period.
I can't find any settings for defrost, but that cycle should only last a like 30 mins though. It's been plugged in again for an hour or so.
jgrewe
Reader
7/13/20 12:30 a.m.
Yes, but the timers stop working and get stuck in defrost or chill.
Evaporator was frozen solid. Appliance guy cleared most of it out with a heat gun, but there is a nice solid block around the heater inlet for the defrost and I have to let it thaw another 24 hours or so before I can plug it in.
I have saved some meat and cheese, but pretty much everything else is going in the trash :/ On the plus side, its a good time give the inside a deep clean.
The main issue is likely the intake of warm air from a door not sealing properly. The RH door has material bubbled up on the top where it should be flat (manufacturing defect or something) but I didn't catch it under warranty. If the door is left to close under its own weight it will often get stuck. I might have to see if I can tweak this area with a heat gun or something. A new door is $7XX
Is your refrigerator running? Better catch it before it gets away!
