JoeyM
JoeyM SuperDork
5/2/11 8:44 p.m.
OK, I just pulled the rear end off my datsun replica. (This is part of my rip-out-the-drivetrain-to-install-the-firewall™ build methodology.) Since I already have it off, I may as well try to clean it up and rattle can it.....The open sides on the engine bay sort of dictate a painted engine, and I may as well make the rest of it match.
As you can see, the rear end currently has a lovely patina of 70% rust, 30% grime.
How would you guys clean this up and prep it for painting?
oldtin
oldtin Dork
5/2/11 8:53 p.m.
Wire brush, mineral spirits, por 15.
nicksta43
nicksta43 Reader
5/2/11 9:40 p.m.
Off topic but I had a diff cover rust through on a 97 truck I bought a couple of years ago, went to go to work one morning and found the driveway covered in gear lube. I've seen a car sit in the junkyard for fifteen years that never rusted like that.
Wire brush the crap out of it or I like those little 3m sanding disks for stripping crud of in a hurry. Clean it and clean it again with something strong rinse well, dry and paint.
fasted58
fasted58 Reader
5/2/11 9:55 p.m.
pressure wash or degrease, wire brush to remove heaviest rust, brush on muriatic acid to remove rest of rust. repeat as necessary. it will flash in a hurry. paint or coat.
acid is one of my fav tools on steel or weld prep
Rad_Capz
Rad_Capz Reader
5/2/11 10:04 p.m.
Scrape the heavy stuff with a putty knife and a big wire brush then use an assortment of wire wheels and brushes on a drill followed by carefully wiping with wax and grease remover. Be sure to get into the corners and crevices well. Paint as desired.
turboswede
turboswede SuperDork
5/2/11 11:17 p.m.
Soda blast it? Maybe glass bead blast it as well?
On the torsion bar carrier for my 924, I used a wire brush in a drill and just went at it. Once I got it down to reasonably clean, I primed and painted it with Rustoleum rattle cans (satin black hides a lot of imperfections, heh).
GregW
GregW New Reader
5/3/11 6:09 a.m.
Cleane as above and POR 15 or Rustoleum primer over a rust converter like phosphoric acid to neutralize the rust you didn't remove. Then paint with some impact resistant chassies paint.
JoeyM
JoeyM SuperDork
5/3/11 11:34 a.m.
OK, another question for those of you advocating POR15....is it true that normal paints/primers will not adhere to a POR15 surface? My intent was to paint the engine, tranny, drive shaft and rear end red. (Just because I though the red engine would look good)
oldtin
oldtin Dork
5/3/11 11:40 a.m.
Topcoat the por while it's tacky or add a primer coat while there's tack to the por - let it all set up and it will be fine. Otherwise paint has trouble sticking and you about have to use a grinder to rough up por after it sets up.
dj06482
dj06482 Reader
5/3/11 1:05 p.m.
nicksta43 wrote: Off topic but I had a diff cover rust through on a 97 truck I bought a couple of years ago, went to go to work one morning and found the driveway covered in gear lube. I've seen a car sit in the junkyard for fifteen years that never rusted like that.
Had the same problem with my '94 Chevy K1500, except it was a pinhole leak.
JoeyM
JoeyM SuperDork
5/3/11 3:54 p.m.
OK....headed to the garage. We'll see how this goes.
JoeyM
JoeyM SuperDork
5/3/11 6:53 p.m.
It cleans up OK
Now I need to pull the brake lines, leaf springs and wheels off so I can finish it
aussiesmg
aussiesmg SuperDork
5/3/11 7:00 p.m.
POR is designed to be painted over as it fades in direct sunlight, just prep correctly and advise the paint store what you are painting over
tr8todd
tr8todd Reader
5/3/11 7:50 p.m.
I like to paint suspension parts with Hammerite. Good stuff if you can find it. The rustoleum just chips right off.
5EP4cp5HfFFXHCaw5BHf4JTaPNgrQt6Y3W5lBdHkpuzErLturLmfCLlgZEwkGL3u
