Johnboyjjb
Johnboyjjb Reader
6/26/18 7:41 a.m.
Rebuilding the motor in my Neon had me looking for a machine shop. Called in October and they were busy but if I was willing to wait fine. Got the call at the end of February and the bottom end rebuild was done, the flywheel machined, and the valves done. Pay the bill and reassemble.
Motor is in the car and runs fine but leaks oil and we diagnose rear main seal. Out comes the transmission and no rear main seal. Both I and my partner presumed that rear main was part of the bottom end rebuild and so didn't check. Our bad.
Trans is back in the car but it appear the rear main is still leaking. Out comes the trans again and the FelPro rear main is leaking a little. This is part of the engine rebuild kit that was purchased by the machine shop and delivered to us. (Which makes the aforementioned oversight even worse.) Replaced with Mopar rear main.
Ok. We've fixed it. No. Still leaking oil. From the rear main seal. Pull the trans again and see that the flywheel is dry. It's not the rear main. It's the oil galley expansion plug . . . that was installed as part of the bottom end rebuild by the machine shop.
So now that we've diagnosed and fixed it, do we have recourse with the machine shop?  Should we expect anything? Do we have a reasonable position to ask? Or are these things that happen and can't really be blamed or supported by the machine shop?
zordak
zordak Reader
6/26/18 9:55 a.m.
I would go over to the shop and talk to the manager and try to have a civil discussion about it. My opinion is that an ok shop will at least offer an apology, a good shop will offer some compensation. and a great shop (short of getting it right the first time) will ask you what it will take to make it right.
APEowner
APEowner HalfDork
6/26/18 10:04 a.m.
I'd certainly let the machine shop know about the leaky galley plug.  If they're any good they'll want to know.  I don't know that I'd expect anything more than an apology but they might offer a price break the next time you need their services or a small refund for your labor.
stylngle2003
stylngle2003 Reader
6/27/18 9:11 a.m.
I'd expect them to reimburse you for the cost of a new plug, but that's about it.
ZyqPluRRtCns8FlD6ByPWFTiJxbpgP3W5E0lhrmvbisxivVDM8p2ScISVuD3g3Yj
