volvoclearinghouse wrote:gearheadE30 wrote: Noice. I just cranked the governor on mine. 5.5 hp factory, but 3100 rpm rating so that it's nice and quiet. I don't want quiet when the grass is long, because operating speed is basically torque peak. As soon as rpm drops, you're falling down the torque curve. Set to 3600 rpm, now when it lugs back, torque increases as it does so. Much, much harder to stall now.From the HF cut-sheet, peak torque (6.6 lb-ft) is at 2500 RPM! Truth be told, I'm a bit wary of this engine to withstand high (over the 3200 RPM listed redline) RPM. For $99, we'll see how well it lasts. Also, interestingly, the oil fill is also the drain. You have to tilt the mower over to drain the oil out. That's, um, interesting.![]()
I should probably clarify that I don't have the HF engine...it's a Kohler vertical shaft. Now that I've dug into it more, the 'recommended efficiency' governor setting is 2800 rpm, but the engine is rated to 3600 rpm. I was also surprised by the 9.2:1 compression ratio. Also, I actually couldn't find the torque curve for this engine, so I was basing everything on how it sounded.
I have since lowered it back to stock (which ended up being 2800 rpm ish), since I didn't wait a ridiculous amount of time to mow the lawn this week and it sounded a little excessive running that fast with that little load. Will probably settle at 3200-3300 next time I feel like fiddling with it.
