trigun7469
trigun7469 HalfDork
2/25/14 3:11 p.m.
OHSCrifle wrote: Do you have any ductwork in this attic? Other than that.. SVreX covered it well.
On the side that already has insulation there ductwork for a bathroom fan, otherwise my heating system is run by a boiler and (Pipping)water.
dyintorace
dyintorace UberDork
2/25/14 3:20 p.m.
jimbbski wrote: Try contacting your utility company. They may have agreements with contractors who do this sort of service.
Just called my utility. They provide energy audits - free of charge! I have one set up for next month!
OHSCrifle
OHSCrifle Reader
2/25/14 7:43 p.m.
That's good then. The reason I asked is because ducts in attics are a bad idea. They are typically only wrapped with R6 insulation, so you basically are pre-heating all your cooling air during ac season, and pre-cooling all your heating air during heating season. Lots of energy wasted...
SVreX
SVreX MegaDork
2/26/14 7:09 a.m.
^ Yep^
Good point.
When I discuss air infiltration and leakage, I am also referring to ducts.
Just didn't say it well
Derick Freese
Derick Freese UltraDork
2/26/14 5:08 p.m.
I'm learning a lot in this thread. You guys are awesome.
trigun7469
trigun7469 HalfDork
2/28/14 12:50 p.m.
Yes, thank you everybody, I think what I am going to do is use what I have. Does anybody have any advice on cutting the pink insulation? is a box cutter the best to use?
Dr. Hess
Dr. Hess MegaDork
2/28/14 1:11 p.m.
I use a box cutter. The cheap long skinny blade kind. Just extend the blade all the way out.
SVreX
SVreX MegaDork
2/28/14 6:18 p.m.
Yep, box cutter.
I lay the batt paper side down on a scrap of plywood. Then I use a small board (like a 2' long 1x2) to push down on the fiberglass at the cut line. The box cutter easily cuts completely through the compressed insulation
oEQZER1PpiaEmSDJbxZP65Ry6DbXR5GVSQWLMhzA86u23N6SWS9JSW52TZzCRJrG
