CyberEric
CyberEric SuperDork
11/10/24 8:40 p.m.
I've got two holes/tears in a brand new tarp, each approx 4 inch IIRC (was going to take a pic but it's dark so early). Wind was ripping it across the edges of my solar panels and I didn't realize.
What ideas do you have to fix them? TIA.
VolvoHeretic
VolvoHeretic SuperDork
11/10/24 9:28 p.m.
I've used denim iron on jeans patches to fix boat covers. I would hand sew around the patch edges and the tear with dental floss after ironing.
Purple Frog
Purple Frog Dork
11/10/24 9:30 p.m.
Canvas tarp, or cheap woven plastic (blue) tarp?
1988RedT2
1988RedT2 MegaDork
11/11/24 9:25 a.m.
I have nothing useful to add.
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Ffilmschoolrejects.com%2Fwp-content%2Fuploads%2F2019%2F08%2F660758d72274dbcc61d86c3573d159b9.jpg&f=1&nofb=1&ipt=54d3286955027be03fa2759fcf5976bd2cbb29b8ceb6364bf3c6e3888a402cae&ipo=images
porschenut
porschenut Dork
11/11/24 10:14 a.m.
The challenge is keeping the rip(a weak spot now) from getting bigger.  A couple of grommets and rope could make a shoelace like arrangement wouild help.
11/11/24 10:26 a.m.
If it's the blue plastic ones, I wonder f a bicycle tire repair kit would do it.  Cut up a tube for the long tears.
CyberEric
CyberEric SuperDork
11/11/24 1:08 p.m.
It's woven plastic from what I can tell.
VolvoHeretic
11/11/24 1:40 p.m.
Buy a small sized poly tarp of the same type and cut it up for a patch and evidently use JB Weld Polyethylene glue.
Resin-Expert.com: Polyethylene and Polypropylene Glue – How to Bond Thermoplastics
Steve_Jones
Steve_Jones UltraDork
11/11/24 3:03 p.m.
How big are they? Harbor Freight has tarps so cheap, it's not worth the time to repair
CyberEric
CyberEric SuperDork
11/11/24 3:40 p.m.
They are 12' x 10' I believe. I thought maybe there was a cheap patch kit or something but maybe it's not worth it. Maybe I can just throw some duct tape on both sides of the hole? Or flex seal tape? Has anyone used that?
I could look how much a smaller tarp is and use the jb weld idea, but I may as well just buy another full size tarp in that case... I'm leaning toward tape at this point as it sounds like there isn't a tarp patch kit that anyone knows of.
I like the idea of a bicycle tire repair kit, thx.
lotusseven7 (Forum Supporter)
lotusseven7 (Forum Supporter) Dork
11/11/24 3:44 p.m.
stuart in mn
stuart in mn MegaDork
11/11/24 3:51 p.m.
For a tarp that size it's probably going to be cheaper to just buy another one.  If you still want to try fixing it, back in the day a lot of guys used this method for patching tears in dirt bike motorcycle seats: cover the hole with duct tape, and then heat up the tape with a heat gun or a propane torch.  You have to be careful if you use a torch so you don't melt the tarp.  This will 'weld' the tape to the tarp, and it will probably hold up for quite a while as long as the tarp isn't whipping in the wind.
adam525i
adam525i SuperDork
11/11/24 6:08 p.m.
Gorilla tape is the one to go with using this method. I haven't fixed a tarp with it but I have patched some wheel well liners and with the heat applied and stuck in it has held up well for a month now, we will see what winter brings. I believe ¯\_(ツ)_/¯  does this on the underside of his rally cars and that was where I first read about it.
californiamilleghia
californiamilleghia UberDork
11/11/24 6:19 p.m.
stuart in mn said:
 cover the hole with duct tape, and then heat up the tape with a heat gun or a propane torch........
Do you only put the Duct Tape on one side ?
When I am patching a car cover hole I try and put the tape on both sides , so near the center of the hole it has a chance for the duct tape glue touching  the other layer glue at some point ,
I never tried the heat gun but will next time.......thanks for the  idea
stuart in mn
11/11/24 6:28 p.m.
I think for a tarp, since both sides are accessible I'd put the duct tape on both sides.
CyberEric
CyberEric SuperDork
11/11/24 6:31 p.m.
Thanks for the tip about heating up gorilla or duct tape, that sounds like a good idea.
@lotuseven7, thx I had no idea they were that cheap.
I still want to fix it though, so I don't have a useless tarp. And I think the hot tape trick might be what I try. I do both sides if I do it.
VolvoHeretic
11/11/24 7:03 p.m.
They make permanent Gorilla tape and by accident, I found out the hard way.
Menards.com: Gorilla® 1.88" x 25 yd Black All-Weather Permanent Duct Tape
1988RedT2
1988RedT2 MegaDork
11/11/24 7:24 p.m.
In reply to VolvoHeretic :
You mean.....  you got it on your hootus?
11/11/24 8:11 p.m.
It would also reinforce a point where there are known issues.  Like elbow pads on a jacket.
6CGybVrm3W4S0ViOWKnUssv3Xz3NEGssAqKSW1Ul95XvJEgHgKpYxEWlQbrZOREb
