Grtechguy
Grtechguy MegaDork
5/26/18 7:48 a.m.
the OE wheel lock key shattered.    How else to get this lock off?
There is a rotating shroud on the outside that negates pounding a socket on it.
xredx
xredx New Reader
5/26/18 7:50 a.m.
Can you weld a nut to it?
Grtechguy
Grtechguy MegaDork
5/26/18 7:52 a.m.
In reply to xredx :
Can you weld chrome plate lugs with a HF Fluxcore?  Being recessed is another issue for trying that.
Fueled by Caffeine
Fueled by Caffeine MegaDork
5/26/18 7:52 a.m.
Run_Away
Run_Away HalfDork
5/26/18 7:56 a.m.
Ooo, Mopar locking lugs.
I have fought these before. What I did was grind down the outside lip of the lug so the rotating sleeve could be slid off, then pounded on the closest sized socket on to the remaining lug to remove. Once you have a socket on there, use an impact and let it spin/slip. The heat generated will expand the lug until it catches and spins off the stud.
Alternatively, a trip to the dealer where they have a master key set will work.
xredx
xredx New Reader
5/26/18 7:59 a.m.
Grtechguy said:
In reply to xredx :,
You might have to chip some chrome off with a chiesel to strike an arc, but it should work.
thestig99
thestig99 Dork
5/26/18 8:08 a.m.
Nuke the vehicle from orbit.
akamcfly
akamcfly Dork
5/26/18 8:13 a.m.
It's too many stories like this that motivated me to replace the locking lugnuts on my new-to-me truck with regular hex lugnuts. They don't match the OE in length, but they're the same across the flats.
My understanding from reading (you've been warned) about welding on chrome plated tubing is that you can, but it will damage the plating. I don't expect that would upset you much as you likely want to see those locking lugnuts die in a fire anyway.
EastCoastMojo
EastCoastMojo Mod Squad
5/26/18 8:21 a.m.
Time to get a shotgun.
Dr. Hess
Dr. Hess MegaDork
5/26/18 8:22 a.m.
Yeah, welding through chrome with a HF flux core welder is no problem.  However, everyone needs a Mossberg 500 or 590.
Grtechguy
Grtechguy MegaDork
5/26/18 8:57 a.m.
I ended up running to the local dealer.    They destroyed one of their wrenches in the process.
Replaced all 4 locking wheel lugs with standard.   cost?   $0.
Guess not all dealerships are bad.
Need to convince the wife for the Mossberg.
Dr. Hess
Dr. Hess MegaDork
5/26/18 9:21 a.m.
Good Job!
I replaced all those things with factory standard lugs on my cars.  Not cheap at like ten bucks a pop or better for a Lexus, but well worth it to me.
Mndsm
Mndsm MegaDork
5/26/18 12:09 p.m.
I would have just thrown the car out. Ain't nobody got time fo that.
Grizz
Grizz UberDork
5/26/18 12:35 p.m.
Show her the prices for the 590 and then tell her you're saving money by getting an 870 instead.
The plan is flawless.
Dr. Hess
Dr. Hess MegaDork
5/26/18 12:39 p.m.
Grab a gun had either 500's or 590's for 99 bucks last week.
Mossberg 500 v. Remington 870.
Grizz
Grizz UberDork
5/26/18 12:44 p.m.
Why would you destroy the lie I told myself to keep me from buying another shotgun.
Spoolpigeon
Spoolpigeon PowerDork
5/26/18 2:45 p.m.
Call around to you local tire shops and see if any of them have a master key set. The Big-O Tires local me has one with close to 100 different keys. They charge a small fee to remove them. Pretty awesome stuff.
The0retical
The0retical UltraDork
5/26/18 8:21 p.m.
As stupid as this sounds, the safety placement of the 500 was the deciding factor in my purchase of a 20ga 500. It's idiot proof.
MazdaFace
MazdaFace HalfDork
5/26/18 9:25 p.m.
I went with a Maverick 88 years ago. Suits my needs fine
aircooled
aircooled MegaDork
5/26/18 9:42 p.m.
It IS the only way to be sure.
nutherjrfan
nutherjrfan SuperDork
5/27/18 1:08 a.m.
Fueled by Caffeine said:
Well he could probably get a gig with the blue man group and also most likely marked his rims. Listening to Eminem probably made him impatient.laugh
akamcfly
akamcfly Dork
5/27/18 9:11 a.m.
Now McFly's shotgun shopping...
Scott_H
Scott_H Reader
5/28/18 1:20 p.m.
Turbo sockets.  These are the female version of the easy-out.
The ID of the socket is spiral shaped with aggressive "threads" that are such than when you turn it counterclockwise, the socket screws itself onto the lugnut.  These threads are tapered with them getting smaller deeper into the socket.  Pricey $$$$ though.
RevRico
RevRico UberDork
5/28/18 1:23 p.m.
Not an axe. I do have a plasma cutter though, wonder how that would work.
pinchvalve
pinchvalve MegaDork
5/28/18 9:17 p.m.
I wonder if a Gator Grip Socket would work?
3vPnbGQBIKQeW1soXUjWpfBWUCmHhQWHVf7kdbfH9BmtMRfKHOwmRb3IJ94Q50Sb
