bearmtnmartin
bearmtnmartin Reader
6/3/12 11:12 p.m.
I have a Line Ward line puller. The eccentric gear has broken down in the valley between the gearbox and the motor. I have completely disassembled the drive system but I cannot figure out how to get the gear out. It seems to be suspended by stub shafts between the two bearings, but do I build some kind of a puller? Is there a hidden circlip?
I'm stumped.
Anyone?
RealMiniDriver
RealMiniDriver SuperDork
6/3/12 11:44 p.m.
Is it a press-fit shaft, through the gear? Can you see both sides of the shaft, outside the case?
bearmtnmartin
6/4/12 12:25 a.m.
Nope. There is a sprocket pressed into a roller bearing which is pressed into the case. Case is cast in a sort of U shape and the exact same arrangement is on the oposite side of the case. Suspended in the middle is the gear. (actually sort of a single throw crankshaft arrangement. ) I cannot see most of the bearing behind the gear and I cannot see down into the valley where the gear is suspended. I think there is a puller the factory uses.
akamcfly
akamcfly HalfDork
6/4/12 7:25 a.m.
Any pics?
Toyman01
Toyman01 PowerDork
6/4/12 8:47 a.m.
Have you tried calling the company. Looks like they have a pretty good parts department which usually means they have someone that works on them.
Line-Ward
157 Seneca Creek Road
Buffalo, New York 14224 USA
Toll Free: (800) 816-9621
Phone: (716) 675-7373
Fax: (716) 674-5334
email: info@lineward.com
pinchvalve
pinchvalve PowerDork
6/4/12 8:53 a.m.
I really need $10, but I don't even know what a line puller is. Photos of the problem area?
integraguy
integraguy UltraDork
6/4/12 11:31 a.m.
Hmmm, I THINK I know what a line puller is but if it's what I think it is...never saw one break and just assumed you head to buy a new one when it did.
ultraclyde
ultraclyde Dork
6/4/12 12:27 p.m.
akamcfly wrote: Any pics?
+1
SYng8TWn9pjazPiXHVL7tCvNh4zDYPxNwMvX6NCM4XQfCHv52R6zSlVjx4m2Q52D
