hybridmomentspass
hybridmomentspass HalfDork
4/7/22 1:56 p.m.
Well, sort of.
For the first time in my life, I worked on a Miata this past weekend, installing a Hard Dog rollbar into a NB my buddy owns.
It wasnt fun.
But I feel like Im officially a GRMer now
4/7/22 2:14 p.m.
Congrats :)
Rollbar installs are a pain. It's like Mazda didn't really intend you to put one in there.
Stampie
Stampie MegaDork
4/7/22 2:14 p.m.
In reply to hybridmomentspass :
Yeah roll bar install isn't fun with all the cutting of the rear deck.
hybridmomentspass
4/7/22 3:02 p.m.
Rear deck was the EASY part...it was those danged 3 bolt holes per side on the top by the fuel tank. The forward-facing ones were super easy...others not so much.
IF I ever have to do it again I'd cut the heck out of the top deck for more clearance.
4/7/22 3:18 p.m.
You had a 12' drill bit, right? That's the key. That and taking the seats out. I usually drill one of those three holes from above, then use the backing plate as a template to drill the other two from below.
The top can be a little bit of a PITA to work around, that's my biggest complaint.
AWSX1686 (Forum Supporter)
AWSX1686 (Forum Supporter) UltraDork
4/7/22 3:36 p.m.
In reply to Keith Tanner :
12" drill bit was a life saver for my NB roll bar install. Otherwise I didn't think it was that bad at all.
KyAllroad
KyAllroad MegaDork
4/7/22 3:57 p.m.
Now try an NC Miata.   That rollbar was a PITA!
4/7/22 4:22 p.m.
I accidentally wrote 12 FOOT drill bit in my post, which is far funnier to think about. A little awkward to use, but at least you're not all hunched over.
hybridmomentspass
4/8/22 8:08 a.m.
seats were out
top was removed
didnt have that long of a bit, but getting to most of those tops are what the issue was.
I did do what you, Keith, suggested, once one was drilled I used the backing plate as a template. But, man, that job wasnt fun.
slefain
slefain PowerDork
4/8/22 9:36 a.m.
Since I've never touched a Miata with a tool, I was instantly thinking it was a situation like the top bellhousing bolts on a 3rd gen F-body. Grab every single socket extension in the shop and remove the bolts while standing behind the rear axle.
akylekoz
akylekoz UltraDork
4/8/22 10:06 a.m.
In reply to slefain :
Been there many times, mostly GM stuff, except I usually stand near the tail shaft.
kp7NpY4TLciS5Om9qNQ0Io15dhmBwLSpS5yVW3PRV74AZ28gcTqT2s0T2gwXCgrp
