Keith
Keith SuperDork
10/16/09 1:03 p.m.
Giant Purple Snorklewacker
Giant Purple Snorklewacker Dork
10/16/09 1:06 p.m.
Nucking Futz
DukeOfUndersteer
DukeOfUndersteer Dork
10/16/09 1:08 p.m.
until the chain comes off and bitch-slaps you...
JFX001
JFX001 Dork
10/16/09 1:10 p.m.
DukeOfUndersteer wrote: until the chain comes off and bitch-slaps you...
He'll probably give his left arm for that bike.
unevolved
unevolved New Reader
10/16/09 1:13 p.m.
I don't see what's so incredibly dangerous about that, provided the chain is adequately guarded. I've driven much worse constructed vehicles.
Capt Slow
Capt Slow Reader
10/16/09 1:14 p.m.
This is a good illistration as to why nothing is idiot proof: because idiots are so berkeleying ingenious
DukeOfUndersteer
10/16/09 1:15 p.m.
Insert:
Dr. Hess
Dr. Hess SuperDork
10/16/09 1:27 p.m.
That's a shovelhead. It won't run long enough for the chain to break.
GameboyRMH SuperDork
10/16/09 2:21 p.m.
This makes that 500HP hayabusa look like a 2009 Camry.
Dr. Hess
Dr. Hess SuperDork
10/16/09 2:38 p.m.
Sorry, my bad, that's an iron head Sportster. It won't run long enough to start.
jwc38
jwc38 New Reader
10/16/09 3:24 p.m.
I wonder what its like to lean on a supercharger
Spinout007
Spinout007 Reader
10/16/09 10:53 p.m.
If it does run long enough with you leaning on the supercharger, I wonder what it's like to have a roots style supercharger blow under your chest..... Bet it's a once in a lifetime experience.
warpedredneck
warpedredneck New Reader
10/17/09 9:28 a.m.
Giant Purple Snorklewacker wrote: Nucking Futz
times 1 million!
motomoron
motomoron Reader
10/17/09 11:01 p.m.
I really like how the shaft on that angle gearbox cantilevers out about 8" so tension on the tight side of the chain can get good purchase on it.
Unless the "builder" comes up with chain guides they're off in seconds and that shaft is bent.
Talented young engineer I work with was going to make his Geo Metro into a hybrid using a golf cart motor. His intent was to chain drive it of the end of the crank. I advised him as to the existence of Gates toothed belts but he was having none of that. "No way are those strong enough" he offered with the full conviction of his engineering degree.
mad_machine
mad_machine SuperDork
10/17/09 11:05 p.m.
so why not turn the superchager transverse like the engine and angle the scoop towards the front? Seems like it would save a few metres of chain
MitchellC
MitchellC HalfDork
10/18/09 12:23 a.m.
It would have been so much easier to put a Japanese straight-4 in there. I'm sure that there's something he can misalign on one to get the characteristic Harley potato-potato-potato-potato....
Trans_Maro
Trans_Maro HalfDork
10/18/09 12:50 a.m.
Rube Goldberg would be proud.
Shawn
Trans_Maro
Trans_Maro HalfDork
10/18/09 1:00 a.m.
Sorry, it appears that the profanity filter doesn't work on signatures!
All better now.
DrBoost
DrBoost HalfDork
10/18/09 7:23 a.m.
motomoron wrote: "No way are those strong enough" he offered with the full conviction of his engineering degree.
I think most of the dumbest things I've ever heard came out of the pie-hole of an engineer.
To make a long story short, I had a Ford engineer trying to convince me that we could simply unbolt the front cross member to remove it. This was after I mentioned the little fact that it was welded to the frame, three times!!! I guess the Ford engineering department has a special tool to unbolt welds ???
Grtechguy
Grtechguy SuperDork
10/18/09 7:37 a.m.
Dr. Hess said: That's a shovelhead. It won't run long enough for the chain to break.
Dr. Hess wrote: Sorry, my bad, that's an iron head Sportster. It won't run long enough to start.
I love Harley owners that admit Harley's are crap ;)
aussiesmg
aussiesmg SuperDork
10/18/09 8:21 a.m.
Good thing the tank can only hold enough gas to get it off the trailer at the show
ansonivan
ansonivan Reader
10/18/09 11:00 a.m.
Looks like one of the super elaborate motor powered things I used to make from lego as a kid... I knew they would fly apart when switched on but I built them anyway.
Does someone have a link to a build thread? I want to follow this one.
DxxdH4oKVpu85GuEVEtQB7BRDwsDx1UotbQ6tN06dIlRhxEMKYL5QLytFVD0rqVR
