Enyar
Enyar Reader
12/20/12 11:19 a.m.
And where would I find one? Just quietly day dreaming to myself about an idea I had, but will not actually happen. In this dream I would be machining designs out of 3/16 or 1/4 " steel. Not very large, maybe max 2'x2'? How much would that cost?
Grtechguy
Grtechguy UltimaDork
12/20/12 11:31 a.m.
http://diylilcnc.org/
I've seen several DIY setups for under $1000 in materials.
yamaha
yamaha Dork
12/20/12 11:54 a.m.
I don't see prices often when we sell machines, but knowing the ones I've seen pricing for that were massive, ill assume the 10-30k window for small used ones.
With that diy setup, id be worried about tool life.....cnc uses coolant like its going out of style to make the endmills, inserts, and boring bars last longer than a day. Also, those in the industry know how salty the cnc carbide stuff is.
WilberM3
WilberM3 Dork
12/20/12 1:26 p.m.
space permitting you could get a Bridgeport CNC machine. my boss did that and it was a recently gone through machine for something like $4k or less perhaps.
Type Q
Type Q Dork
12/20/12 1:29 p.m.
In reply to Enyar: Are you asking about aquiring a CNC machine or what CNC machine time usually goes for?
motomoron
motomoron Dork
12/20/12 2:29 p.m.
I believe the OP is interested in cutting 2D shapes from steel plate vs. 3/4/5 axis CNC machining.
For that look at PlasmaCAM and Torchmate.
These are very basic stepper motor driven X-Y robots that produce pretty accurate and repeatable parts. They start at a couple grand. There's many online communities that are all into these.
See cnczone, pirate 4x4
CNC milling machines, turn-key, start at the bottom w/ a small Tormach machine at under $20k w/ tooling + SprutCAM software. Next up would be the smaller Haas machines starting at about $30k, Full size machines w/ a seat of masterCAM are $50k on up.
There's a huge market for used machinery where it's possible to buy a good used machine for $4k or 6 tons of scrap iron for $20k.
The main thing I'll offer as someone with a full machine shop of manual machines w/ digital readouts is: A machinist can learn CAM and make parts w/ a CNC machine. A CNC machine cannot, however, make someone a machinist.
novaderrik
novaderrik UltraDork
12/20/12 3:39 p.m.
getting an old Bridgeport mill that has cnc controlled axis motors would be on the cheap side of things... getting an actual full on cnc machining center with a tool changer and what not would get into the more expensive side of things.. either way, the tooling is what will kill you.
i get paid to play with a mid 90's Fadal 4020 VMC 40 hours a week, and i have the freedom to make my own stuff on it at any time as long as i get the work stuff done so i really have no need to look into how much this stuff actually costs.
CarKid1989
CarKid1989 SuperDork
12/20/12 4:16 p.m.
Dr. Hess
Dr. Hess UltimaDork
12/20/12 4:37 p.m.
A friend of mine bought a HF mini (micro?) mill on eBay that had been converted to CAM. I think he paid about $400 for it. Software is free (open source). He said that any mill can be converted to CAM for not much by buying the servos and building a controller box.
ValuePack
ValuePack Dork
12/20/12 9:32 p.m.
motomoron wrote: A CNC machine cannot, however, make someone a machinist.
Amen to that. I work for a sizeable screw machine house. Of the ~70 machinists, I can count on two hands the number of actual machinists.
+1 for anything Bridgeport.
novaderrik
12/20/12 10:06 p.m.
Wonkothesane wrote: Huh, looks like you can pick up a CNC'd brideport for 3-5k on craigslist..
yeah.. and how worn out are they at that price point? from where i'm sitting right now (at my Fadal cnc machine), i can see 6 manual milling machines.
3 Bridgeports, a Comet, a Millport, and an Ultima...
of those, only one of the Bridgeports is good for anything that requires tolerances tighter than about .030- it's pretty solid down to about .001 over about a foot, which is more than good enough for what we do- the rest are just flat out worn out junk that you'd have to pay me to take, but the company keeps them around because different people like the different machines.. one of them has the cnc stuff on it because someone decided that he wanted to try to make it into a cnc end hole machine, but thankfully it's not the good one.
yamaha
yamaha Dork
12/21/12 1:19 a.m.
novaderrik wrote: either way, the tooling is what will kill you.
Quoted for truth......I have craploads of Sandvik, Iscar, Walter, Guhring, Kennametal, Melin, Huele, and such cross my desk every week. Its terrifying to see a small plastic box the size of a pack of gum cost upwards of $100 for 10 little bits of metal.....
Most of our customers that I go to seem to have Gleason's IIRC. The windmill gearbox plant has the biggest I've seen though, look like the size of a small house.
redrabbit
redrabbit Reader
12/21/12 2:08 p.m.
The CNC Bridgeport is a good starting point. The shop I work for just bought a new Haas Mini Mill for about $40,000. I saw a Lincoln cnc plasma cutter at a car show last year. HGR has a website, if you get a chance, visit ! I think they serve lunch on Wednesdays.
porschenut
porschenut Dork
2/28/25 7:23 a.m.
When you decide to actually crunch real numbers consider buying cnc time instead of buying the machine, paying for setup and power connections, etc.  I designed a neat part for mountain bikes years ago, made the first one with a drill press and a file.  A local machine shop with CNC made them for a buck a piece out of stainless which I could never beat with a machine until volumes were over 10K.
RX8driver
RX8driver Reader
2/28/25 10:11 a.m.
At work we bought a CNC plasma off Amazon (yes, seriously) for $2900 Canadian that'll do a 5x10 sheet. with smaller versions also available for slightly less. They could easily be cut down for a smaller space. Table and torch not included, but it does come with some clunky Chinese software to convert a CAD drawing to a file readable by the machine. It works remarkably well for what it is for our occasional use. We had a torch, air supply and table from an old system that traced paper drawings, but stopped working, so it was worth a try. There are lots of good, free CAD programs out there.
It's probably a much better decision to farm out the CNC cutting for 99.9% of everyone on this forum though.
californiamilleghia
californiamilleghia UberDork
2/28/25 11:16 a.m.
Just talked with my buddy up in San Jose and he mentioned they were going to pick up another FREE Bridgeport  today , its his 3rd free one ,
No idea how the tolerances  are on this one but the others were pretty good for automotive work.
Is there a good YouTube  video on how to check out a Bridgeport type machine ?
C4u39tsxfvhOMAVbAW7jAjiEf2teskeidJ3LPHntIXSx0RHdoghpXUrdgeLQRDxS
