mndsm
mndsm MegaDork
8/28/15 9:50 p.m.
cheese grater. Good thing these tires were about dead anyhow.
skierd
skierd SuperDork
8/28/15 10:06 p.m.
Will
Will SuperDork
8/28/15 10:07 p.m.
What's with the lugnuts?
secretariata
secretariata HalfDork
8/28/15 10:10 p.m.
Will wrote: What's with the lugnuts?
Mad Max fantasies?
mndsm
mndsm MegaDork
8/28/15 10:15 p.m.
Its sort of a long story- the short version is I found them hilarious and they came in neo chrome.
Streetwiseguy
Streetwiseguy PowerDork
8/28/15 10:16 p.m.
Lucky no ABS, or the emergency stop would have been panic and collision.
mndsm
mndsm MegaDork
8/28/15 10:19 p.m.
Streetwiseguy wrote: Lucky no ABS, or the emergency stop would have been panic and collision.
Well, I was already on the shoulder because of the asstard in front of me not knowing how to work a brake pedal. 22 year old corolla vs new Acura, one of us has a shorter braking distance. You get used to having a way out in this car.
8/28/15 11:26 p.m.
I figured with those nuts, you're living your Ben Hur fantasies to the best of your abilities.
Kenny_McCormic
Kenny_McCormic UltimaDork
8/29/15 12:06 a.m.
Threshold braking!
z31maniac
z31maniac MegaDork
8/29/15 12:54 a.m.
Like not following so close you have to pull to the shoulder in the case of emergency braking?
Travis_K
Travis_K UberDork
8/29/15 3:17 a.m.
Unfortunately, when driving in traffic in an older car, the space other drivers allow you to leave between you and the car in front of you often isn't sufficient to be able to stop comfortably when someone makes a max effort stop in a brand new car.
moparman76_69
moparman76_69 UltraDork
8/29/15 7:11 a.m.
If you're in traffic here and you leave a gap big enough for a car, someone will cut you off. Sometimes they so it even when they don't have the room.
mndsm
mndsm MegaDork
8/29/15 7:45 a.m.
Pretty much this. Plus I had a guy on my ass in some sort of jacked up.E36 M3box of a truck with some Chinese as berkeley hids blinding me- so the odds were not ever in my favor.
Ian F
Ian F MegaDork
8/29/15 8:07 a.m.
Wow... I bet that caused a bit of vibration once you got moving again...
wbjones
wbjones MegaDork
8/29/15 8:25 a.m.
Kenny_McCormic wrote: Threshold braking!
possible just a tiny bit past threshold
wbjones
wbjones MegaDork
8/29/15 8:27 a.m.
just another reason to be happy I live a much more rural live than that
traffic here has no resemblance to that
8/29/15 9:34 a.m.
He runs a metrosexual dungeon.
ProDarwin
ProDarwin UberDork
8/29/15 9:49 a.m.
mndsm wrote: 22 year old corolla vs new Acura, one of us has a shorter braking distance. You get used to having a way out in this car.
They should have a very similar braking distance if you have decent tires... which it appears you may have had, but certainly do not anymore
Will
Will SuperDork
8/29/15 10:10 a.m.
When you said rumble strips, I was thinking on a road course, not on the street. And honestly, those lugnuts seemed a little inappropriate for track use.
mndsm
mndsm MegaDork
8/29/15 10:10 a.m.
Ian F wrote: Wow... I bet that caused a bit of vibration once you got moving again...
That's how I discovered there was a problem. I figured I'd gotten some pea gravel stuck in it (the gravel was from the shoulder, theve been "improving" the road there) or a little flat spot. When I stuck my hand in there and felt that, I knew it was a bit more serious. Visuals confirmed. I was rather impressed at the efficient effort that the shoulder took to destroying my tire.
iceracer
iceracer PowerDork
8/29/15 11:59 a.m.
Rumble strips mean you are not supposed to be there.
mndsm
mndsm MegaDork
8/29/15 12:11 p.m.
It was an evasion situation.
captdownshift
captdownshift UltraDork
8/29/15 12:12 p.m.
If the rumble strip are painted and it's wet, you won't slow down
madmallard
madmallard Dork
8/29/15 1:35 p.m.
In reply to mndsm:
:( did it make a spectacular noise, at least?
mndsm
mndsm MegaDork
8/29/15 2:46 p.m.
madmallard wrote: In reply to mndsm: :( did it make a spectacular noise, at least?
Well the actual stop sounded a lot like running over a rumble strip and gravel flinging all over my car. The ensuing drive was spectacularly loud though.
PKAAfNPFl4NuscfUGJnRZtCEWCD7H41ucRDMcP7J8sOUIFrq2vLpvwOaI6zkZwOV
