Will
Will Dork
10/14/11 5:57 a.m.
Streetwiseguy wrote:
Gearheadotaku wrote: my 89 Chevy has a shifter marked 1-2-3, with an 'L' for the compound low. Does this count as a 3 speed for this discussion?
Not directly, but I bet its the last 4 speed standard shift trans available. I'm pretty sure they added overdrive 5th on those in 90.
Wasn't a 4-speed available on the second gen CRX DX, and Civics of the same era?
Streetwiseguy
Streetwiseguy Dork
10/14/11 7:57 a.m.
Certainly possible- I remember having a hell of a time finding the right clutch for a 4 speed Civic at one time, since most of them had 5 speeds. I don't remember the vintage of the car, though.
pilotbraden
pilotbraden Dork
10/14/11 8:41 a.m.
I would wager that a 3 on the tree could be left with the keys in it, parked in a bad area for quite a while without being driven away.
griffin729
griffin729 HalfDork
10/14/11 8:50 a.m.
My '79 CJ-7 had 3 on the floor, though 1st was geared so low it was pretty much a 2 speed.
spitfirebill
spitfirebill SuperDork
10/14/11 2:42 p.m.
I learned to drive in an early 50s Plymouth with 3 on the tree.
I also had a 64 Olds F-85 with 3 on the floor. Had the mightly 225 Dauntless V-6.
pinchvalve
pinchvalve SuperDork
10/14/11 2:47 p.m.
My 1987 Nissan Stanza had a three-speed. (1st and 5th stopped working, along with reverse.)
Woody
Woody SuperDork
10/14/11 2:58 p.m.
Not the CRX, but the base Civic was a four speed, at least up to 1991.
ReverendDexter
ReverendDexter SuperDork
10/14/11 3:10 p.m.
I know my friend's dad had an 80's bodystyle E150 that had a column shift manual... did those ever come as a 4-speed? If not, I suspect it's the last of the non-automatic 3s.
fasted58
fasted58 SuperDork
10/14/11 4:38 p.m.
Wiki says last North American column shift was '87 Chevy PU
Nitroracer
Nitroracer SuperDork
10/14/11 10:54 p.m.
novaderrik wrote: i've seen a couple of mid 70's Chevelles with a 6 cylinder and a 3 on the tree.. i'd love to see anyone under the age of 30 try to drive one of them..
I'm only 24 but I'd love to give it a shot. Some times I wish my fairlane was a column shift manual just to give it a try. Probably wouldn't want it for daily use though.
novaderrik
novaderrik Dork
10/15/11 12:12 a.m.
actually, it's not that bad once you get used to the shift pattern and as long as the linkages are all properly adjusted.
Trans_Maro
Trans_Maro Dork
10/15/11 1:03 a.m.
Nitroracer wrote: I'm only 24 but I'd love to give it a shot. Some times I wish my fairlane was a column shift manual just to give it a try. Probably wouldn't want it for daily use though.
Why not?
I drove a column shift three-speed for years as a daily and I'm only 34.
It's no worse than any other shifter.
Makes automatics a bit rough though. I stuffed our old work van into park trying to grab another gear one day.
Shawn
mtn
mtn SuperDork
10/15/11 2:19 a.m.
I'm only 21; I've only seen one in person. I'm pretty sure that I could drive one if I were allowed 30 seconds playing around with the shift pattern before hand. It isn't any different than driving a floor mounted manual, how hard could it be?
(Don't say that!)
novaderrik
novaderrik Dork
10/15/11 4:37 a.m.
mtn wrote: I'm only 21; I've only seen one in person. I'm pretty sure that I could drive one if I were allowed 30 seconds playing around with the shift pattern before hand. It isn't any different than driving a floor mounted manual, how hard could it be? (Don't say that!)
i drove an 87 Celebrity with a column mounted automatic for 7 months.. i've been driving an '04 Cavalier with a floor mounted automatic for about a month.. about every 4th time i get in the car, i hit the windshield washer squirter when i want to put it in gear..
driving a 3 on the tree is kind of like that at first, but it's actually a very intuitive way to drive once you get used to it.. there is a part of me that wants to figure out a linkage in something to shift a modern internal rail 5 speed overdrive trans with a column shifter..
iceracer
iceracer SuperDork
10/15/11 9:20 a.m.
The shift pattern is the same whether on the wheel or on the floor. Just flipped 90 degrees.
Twin_Cam
Twin_Cam SuperDork
10/15/11 11:03 a.m.
HappyAndy wrote: My '83 F-150 had an I-6 and 3 plus O/D. Ford called it a 4 speed, but for all intents it was a 3 speed, O/D was useless below 50mph.
Co-worker just bought that exact truck but it's an '85.
pitbull113
pitbull113 Reader
10/15/11 2:15 p.m.
i had a '81 chevy g10 van with a 250 6cyl. and 3 on the tree. loved that van
0mfZBsRsssUha99FvhYZdBuafxK5cqfJa1Jpv8ZFCn3WPa1aet9gNV5Kd3F2pObn
