1988RedT2
1988RedT2 MegaDork
3/23/24 11:00 a.m.
Putting the finishing touches on the Chevy II.  Adding fluids.  Got the bling-ey Billet Specialties water neck.  It comes with a nifty rubber O-ring that will contact the surface of the manifold just outside the thermostat.  Problem is, that area is a mite pitted.  How to proceed?  Ship it?  Add a gasket?  Add a gasket sealer?  RTV?
TIA!
ShawnG
ShawnG MegaDork
3/23/24 11:05 a.m.
Those o-ring sealed units suck.
Try some anaerobic sealer on the flange before you put the water outlet on.
3/23/24 11:32 a.m.
Skip the blingy-thingy and use a cast outlet. Seal it with a Felpro 35562T gasket. You could try this gasket with your fancy outlet and see if you get lucky. Its plastic with a rubber seal, much bigger than a o-ring.
I wonder if you could fix those pits with a little epoxy or JB weld.
1988RedT2
1988RedT2 MegaDork
3/23/24 11:48 a.m.
Gearheadotaku (Forum Supporter) said:
Skip the blingy-thingy and us a cast outlet. Seal it with a Felpro 35562T gasket. You could try this gasket with your fancy outlet and see if you get lucky. Its plastic with a rubber seal, much bigger than a o-ring.
Ah!  I had considered this.  Pretty easy to do, really.  I think I have some epoxy that might still be good.  I think that's going to be my strategy.  Even if I don't do a great job, it's bound to be better than it is.
Edit:  Sorry, the blingy-thingy stays.  Wife's car.  Wife likes the bling.
Ranger50
Ranger50 MegaDork
3/23/24 12:26 p.m.
It's a damn thermostat. File the surface flat. Paper gasket and some anaerobic sealer.
3/23/24 12:45 p.m.
Ding!  Ding!  Ding!
Remove the thermostat, stuff a rag in the hole and draw file the surface, then use some emery on a hard sanding block.  Ensure your strokes are east-west, then north-south to prevent curving the surface.
1988RedT2
1988RedT2 MegaDork
3/23/24 12:54 p.m.
Hmmm.  I haven't tried to measure it, but I'd say that big crater is at least 1 mm deep.  Thinking I'd prefer to fill it, since some of the surface is now flat.  When I get done filing it, I suspect it would be no longer flat.
Noddaz
Noddaz PowerDork
3/23/24 1:07 p.m.
And this does not quite work.  So I will not take credit for it.
1988RedT2
1988RedT2 MegaDork
3/23/24 1:15 p.m.
In reply to Noddaz :
You guys are a riot.  Thanks!  I need to see that she sees this.
Ranger50
Ranger50 MegaDork
3/23/24 2:33 p.m.
In reply to 1988RedT2 :
Devcon epoxy it then.
Cousin_Eddie (Forum Supporter)
Cousin_Eddie (Forum Supporter) SuperDork
3/23/24 3:01 p.m.
Mix up a little batch of JB Weld. Apply it with a razor blade and it should fill in the divots nice and smooth.
93gsxturbo
93gsxturbo UltraDork
3/23/24 4:42 p.m.
I would also JB Weld the craters and then deck it with a flat file or the aformentioned block with some emery cloth.  Or you wanna get frisky, chuck it up in a mill and fly cut the surface.
Curtis73 (Forum Supporter)
3/24/24 1:35 p.m.
60-grit on a chunk of 2x4.
No o-ring neck.  They bend the first time you torque them down.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
3/25/24 10:27 a.m.
It's like this board doesn't make their entire builds out of The RIGHT STUFF
Here is a thread on how to use it on everything https://grassrootsmotorsports.com/forum/grm/need-to-know-everything-about-right-stuff-sealant/85594/page1/
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) PowerDork
3/25/24 11:38 a.m.
I'm reading the responses and thinking "why isn't anyone just using Permatex 'Right Stuff'?"
Thank you, Paul.  At least there are two of us!
ShawnG
ShawnG MegaDork
3/25/24 9:31 p.m.
In reply to SkinnyG (Forum Supporter) :
There's three of us but I'd rather not need a strike-thru scraper and hammer to change my thermostat. cheeky
I'd also be using the factory water neck though, mostly because I had one of those o-ring ones once.
3/25/24 11:22 p.m.
Could always use Permatex Aviation Form-A -Gasket....
.... pity the next guy to go in there.
3/26/24 6:38 a.m.
And then you're filing them flat and using a bead of Right Stuff instead of a gasket anyway, which renders the whole "pits in the manifold" thing moot.
I hated the O ring blingy thingy thermostat outlets.  They ALWAYS warped and bent and leaked.
Right Stuff is always the answer.
3/26/24 6:53 a.m.
8V3rnOZ7LwgLwjEbGDiSkBTjj3iCVNewWIndgOzCohaKJ9v3rgP4mSCDisNMCiqa
