dyintorace
dyintorace PowerDork
5/31/19 8:38 p.m.
NMNA
2008 Land Rover Range Rover Sport Twin Turbo LS Swapped - $25000 (Sanford)
Twin turbo LS swap Range Rover Sport
NO TRADES
Unfortunately I need to let this build go in order to move onto the next chassis development project. This Build is completely fresh and everything has less than 1,000 miles. Everything was purchased brand new within the last 1.5 years.
Idle video here: https://www.youtube.com/watch?v=5pUMHdrFIjI
Clean Florida title, runs and drives perfectly.
Standalone engine/trans harness by PSI Conversions with P01 PCM tuned on 2 Bar speed density
Gen 3 5.3 Iron block LM7 freshly hot tanked and honed
Gen 4 pistons and rods (freshly balanced) with all bearings, rings and gaskets replaced
Melling 10295 Oil pump
New Timing set
Sac City Corvette 3 piece oiling system kit
LS9 Headgaskets with ARP head studs
317 Heads freshly decked and serviced with valve job and trunion upgade
LJMS Stage 1 twin turbo camshaft upgade
BTR .660" lift platinum spring kit
New pushrods , lifters and trays
LS1 intake manifold with Lokar cable throttle and pedal
New crank pulley, Camaro water pump, power steering pump with Dirty Dingo billet pulley
ICT Billet low mount alternator and Power Steering Bracket kit
New DR44G 145amp alternator and battery
MSD Spark plug wire kit with tucked coil packs and new plugs
New O2 sensors and AEM X series wideband
Valve covers modified for -10AN breather fittings
Custom 2.5" schedule 10 stainless hot side with stainless T4 flanges
Borg Warner S366 .88A/R T4 Turbos
Turbosmart 40mm Compgate Wastegates with Turbosmart Big Bubba Stealth BOV
3" Stainless downpipes with v band flanges dumped out of side trim panels
2.5" cold side aluminum piping using Vibrant Vanjen clamps
Stainless braided oil feed and -10AN oil drains
Turboguard inlet screens with headlights modified to feed fresh air
Be Cool Boneyard Series aluminum radiator with Derale 17” electric fan and shroud
Levels Performance custom air to water intercooler setup. Garrett 1,000hp core with 16AN fittings, Davies Craig EWP150 electric water pump, interior mounted reservoir and 3” thick front mounted heat exchanger
Motion Raceworks steam vent kit
Rear Wheel Drive 4L80E Automatic transmission with fresh rebuild
Trans Go HD2 shift kit
Derale 40 Row Remote Mount Trans Cooler/Fan Assembly
FTI 10” single clutch lock up converter
Custom one piece driveshaft
Lokar linkage kit
Dual Walbro Hellcat 525lph fuel pumps in factory tank
Custom Dual pump hangar and lid with AN fittings and Radium connector
Injector Dynamics IDF750 fuel filter assembly
-10AN Feed line to machined fuel rails
Deka 80lb injectors
Fore F2i fuel pressure regulator
-8AN return
K Sport Coilover conversion Less
MrJoshua
MrJoshua UltimaDork
5/31/19 9:20 p.m.
I always assumed this Rover tag I spotted in 2015 was transferred from something else.....maybe I was wrong.
84FSP
84FSP SuperDork
5/31/19 9:39 p.m.
Omg I want this...
6/1/19 12:49 a.m.
That is one clean looking swap.
M2Pilot
M2Pilot Dork
6/1/19 4:47 p.m.
Nice swap, I'm sort of glad it's in Sanford FL and not Sanford NC
z31maniac
z31maniac MegaDork
6/3/19 7:42 a.m.
All of the want.
Brett_Murphy
Brett_Murphy UltimaDork
6/3/19 9:12 a.m.
I was thinking the same thing.
acOEFriUArEvWBnEsvap5Pr8b2mV70BY1F89itJN7bWQ8jBC6z9SQjBIsF4CoX5Y
