curtis73
curtis73 UltraDork
8/10/13 3:24 p.m.
Last year I cut down a Mulberry. I saved the trunk because it was about 6' long and had several wyes in it that might make for some interesting grain. The closest mill I can find is about an hour away and their phone is disconnected so they may be out of business.
1) Anyone know someone with a small mill in or around Pittsburgh PA that would be willing to do such a small project?
2) Is Mulberry a worthwhile wood to use as lumber, or is it kinda boring? I looked through some images and some of it is amazing but most is vanilla.
JoeyM
JoeyM Mod Squad
8/10/13 3:45 p.m.
This guy is not local to you, but obviously does that kind of work. If the GRM hive mind doesn't come up with a local name, call him up and see if he knows someone in your area:
http://www.maizeguitars.com/
pilotbraden
pilotbraden SuperDork
8/10/13 7:26 p.m.
It is a beautiful golden yellow color. Do something with it.
curtis73
curtis73 UltraDork
8/10/13 8:11 p.m.
I was thinking about a dash panel in the 66 bonneville, or maybe finding someone with a lathe and turning a salad bowl set.
SVreX
SVreX MegaDork
8/10/13 8:51 p.m.
I used to have access to a portable bandsaw limber mill, but not any more.
What is the diameter? For just a few slabs, it's not that hard to re-saw on a decent large vertical bandsaw (I've got a 20").
I've also done it with a chainsaw, but it takes some effort with a sander and/or planer. (I'm very good with a chainsaw- timber framed joinery experience, but you can usually find someone local who can do it)
curtis73
curtis73 UltraDork
8/10/13 8:54 p.m.
Diameter is about 28". My biggest problem is that it probably weighs 1500 lbs.
I posted on CL. We'll see what turns up.
pilotbraden
8/10/13 10:50 p.m.
I see an old sawmill rig at old tractor shows here in Michigan. They hook it up to the PTO of a tractor and put on demonstrations. I would wager that your area has some similar type events. Also a chainsaw sawmill can make darn nice lumber.
JoeyM
JoeyM Mod Squad
8/10/13 11:52 p.m.
curtis73 wrote: I was thinking about a dash panel in the 66 bonneville, or maybe finding someone with a lathe and turning a salad bowl set.
Ooh! I like that plan
cwh
cwh PowerDork
8/11/13 9:23 a.m.
Keep the cuttings. Great for a charcoal grill, better than apple or hickory.
benzbaronDaryn
benzbaronDaryn Dork
8/11/13 7:00 p.m.
I saw two guys cutting a redwood slab using a chainsaw. They used an aluminum ladder to provide a straight edge and used wedges to prevent the wood from squeezing the blade. They cut slow. Don't know if this helps or not.
Curmudgeon
Curmudgeon MegaDork
8/11/13 8:23 p.m.
For some reason, people in my 'hood have been cutting down huge beautiful mature trees. There's been a good many pines which I can sorta see because there's so many (I have 5 in my yard alone) but the hardwoods... anyway, someone on the next block up cut a HUGE oak tree out. They now have two 'cuts' from the tree, probably 40" in diameter, that are seasoning next to the house. I have to admit they'll make neat tables.
Hal
Hal Dork
8/11/13 9:48 p.m.
curtis73 wrote: I posted on CL. We'll see what turns up.
You might have to try a couple counties east of you. Somerset PA sawmills
wbjones
wbjones PowerDork
8/12/13 5:56 a.m.
Curmudgeon wrote: For some reason, people in my 'hood have been cutting down huge beautiful mature trees. There's been a good many pines which I can sorta see because there's so many (I have 5 in my yard alone) but the hardwoods... anyway, someone on the next block up cut a HUGE oak tree out. They now have two 'cuts' from the tree, probably 40" in diameter, that are seasoning next to the house. I have to admit they'll make neat tables.
I've got two walnuts in the front yard I'd LOVE to get rid of ... nothing will grow worth-a-E36 M3 under them ...
1 is only ~ 12" dia. the other is ~24" in dia .. wondering if either are worth anything
wwja3uRHBr1QZFLiECO7jSUFlAgryVyLd2pM7y91yOkoRLqj3ZjnllkX6VE1zHTw
