Datsun310Guy
Datsun310Guy UberDork
2/25/13 1:35 p.m.
As I thought about what batteries I had in my 5 remote controls and the flame that was shown from the University last week; I started to wonder how irrelevant or off topic I can be. So I will start........
  1. I can specify out how many pipe guides you will need for any given length of pipe.
Grizz
Grizz SuperDork
2/25/13 1:38 p.m.
357 ft
aircooled
aircooled PowerDork
2/25/13 1:49 p.m.
Please comment on the following issues:
  • Is the distance between guides independent of pipe size?
  • Does the type of pipe (high pressure, hot, cold etc) affect the distance of guides?
  • Is there any issue / compensation for expansion and contraction with temperature?
Wally
Wally UltimaDork
2/25/13 1:55 p.m.
aircooled wrote: - Is there any issue / compensation for expansion and contraction with temperature?
He's a professional, I'm sure he knows about shrinkage
RossD
RossD UberDork
2/25/13 1:59 p.m.
From B31.1, table 121.5: Suggested Pipe Support Spacing:
There are general notes at the bottom of this chart that should be taken into consideration, also.
There are a lot of things to consider when looking at temperature differentials and operating pressure.
Datsun310Guy
2/25/13 2:09 p.m.
aircooled wrote: Please comment on the following issues: - Is the distance between guides independent of pipe size? Pipe guide spacing is dependent on pipe size BUT the first 2 guides are spaced the same from the EJ (and anchor point) ----> (1st = 4XD) then (2nd = 14XD). D = pipe diameter . - Does the type of pipe (high pressure, hot, cold etc) affect the distance of guides? yes, the higher the working pressure, the closer the pipe guides are AFTER the first 2 pipe guides. Temperature was already considered in the thermal growth calculation. - Is there any issue / compensation for expansion and contraction with temperature? Yes. I have to calculate max temp (expansion) and low temp (contraction).
great questions - see above. I follow all EJMA guidelines.
slefain
slefain SuperDork
2/25/13 2:16 p.m.
Does pipe length matter or only how you are using it?
Datsun310Guy
2/25/13 2:18 p.m.
slefain wrote: Does pipe length matter or only how you are using it?
Seriously.
I was hoping you guys could toss back to me a lot more irrelevant crap than the totally irrelevant crap I deal with all day long.
Grizz
Grizz SuperDork
2/25/13 2:20 p.m.
In reply to Datsun310Guy:
Sorry broseph. Here's some garbage for you, I woke up at noon, put on pants at 2 and haven't eaten yet.
Wally
Wally UltimaDork
2/25/13 2:24 p.m.
Oh, I should put on pants. This is the first day in almost a year where I've had nothing to do. I put a turkey in the smoker when the wife left for work and worked on a model truck. It's light now so I should probably have pants on to retrieve mah turkey.
RossD
RossD UberDork
2/25/13 2:27 p.m.
There is a filter with a manufactured date of 1969 in an air handling unit. It's still there. Even now...
1988RedT2
1988RedT2 UltraDork
2/25/13 2:27 p.m.
What if the pipe is buried? Do I still need pipe guides? What about "thrust blocks?"
fasted58
fasted58 UberDork
2/25/13 2:28 p.m.
Do piping engineers chew their fingernails?
Grizz
Grizz SuperDork
2/25/13 2:29 p.m.
Hmmm. I went out drinking with a friend from high school Friday and I'm friends with a stripper now.
If I'm lucky I can get in her pants.
Datsun310Guy
2/25/13 2:30 p.m.
1988RedT2 wrote: What if the pipe is buried? Do I still need pipe guides? What about "thrust blocks?"
then the pipe guides need to be in vaults or man holes. thrust blox are out of my realm.
Datsun310Guy
2/25/13 2:31 p.m.
Grizz wrote: 357 ft
pipe ID?
pipe material?
and I need working pressure?
Datsun310Guy
2/25/13 2:32 p.m.
RossD wrote: There is a filter with a manufactured date of 1969 in an air handling unit. It's still there. Even now...
University.....lots of money to throw around.
e_pie
e_pie HalfDork
2/25/13 2:32 p.m.
I don't think length or use should matter as long as you're laying the pipe well.
Datsun310Guy
2/25/13 2:32 p.m.
Grizz wrote: Hmmm. I went out drinking with a friend from high school Friday and I'm friends with a stripper now. If I'm lucky I can get in her pants.
okay - what precautions do you take with strippers?
JohnInKansas
JohnInKansas Dork
2/25/13 2:34 p.m.
My wife uses thrust blocks when she's trying to sleep and I'm bothering her...
1988RedT2
1988RedT2 UltraDork
2/25/13 2:40 p.m.
JohnInKansas wrote: My wife uses thrust blocks when she's trying to sleep and I'm bothering her...
http://www.youtube.com/watch?v=bcYppAs6ZdI&feature=fvwp&NR=1
Grizz
Grizz SuperDork
2/25/13 2:44 p.m.
Same kind of precautions you take road racing a bone stock car from the 70s. Hold on, go balls deep and hope you don't die.
fritzsch
fritzsch HalfDork
2/25/13 2:48 p.m.
what if im laying pipe on the moon
Grizz
Grizz SuperDork
2/25/13 2:50 p.m.
What if I'm laying pipe on your mom?
Swank Force One
Swank Force One MegaDork
2/25/13 2:52 p.m.
Grizz wrote: What if I'm laying pipe on your mom?
Fill in the blank:
Ron Jeremy lays ___ .
TXXWfpuj4rdshNdN8k1U7EAcw7qfp4j38Kkt8iDDJK7RiGJ1fccmXrTdQr3Y0CFq
