volvoclearinghouse
volvoclearinghouse Dork
8/22/14 7:30 a.m.
Is that serious?
IMG-20140820-02198
IMG-20140820-02202
IMG-20140821-02260
Yup.
bentwrench
bentwrench HalfDork
8/22/14 7:33 a.m.
I think the rod is the least of your worries.
wvumtnbkr
wvumtnbkr Dork
8/22/14 7:35 a.m.
Boat?
fasted58
fasted58 PowerDork
8/22/14 7:37 a.m.
that'll buff out
Klayfish
Klayfish SuperDork
8/22/14 7:40 a.m.
You might be down a few hp now...
What engine was that?
mndsm
mndsm MegaDork
8/22/14 7:46 a.m.
That.... Seems to be an Industrial application.
tuna55
tuna55 UltimaDork
8/22/14 7:51 a.m.
I have insider knowledge as to VCHs current profession and have a few guesses. I'll keep them to myself for now.
Dusterbd13
Dusterbd13 Dork
8/22/14 7:55 a.m.
Little jb weld, head gasket in a can, and some 50wt and it'll get you home.
Hungary Bill
Hungary Bill Dork
8/22/14 7:56 a.m.
Duct tape.
Tom_Spangler
Tom_Spangler SuperDork
8/22/14 7:57 a.m.
The guys on /reddit/justrolledintotheshop would love those pics.
volvoclearinghouse
8/22/14 8:01 a.m.
Industrial application. Turbodiesel, about 170 litre displacement. Threw that rod under load, luckily the oil pressure monitor killed the injectors and shut the engine down. We collected 3 huge boxes of metal shards and debris that I'm sorting through.
BTW- each of those rods is about the size of your arm, and weighs about 50 pounds. That metal bench that goes around the side of the engine- see how it's bent? It used to be straight. Rod went straight out the porthole and bent that bench like that.
tuna55
tuna55 UltimaDork
8/22/14 8:02 a.m.
Next time use a real engine
Some affiliation.
4cylndrfury
4cylndrfury MegaDork
8/22/14 8:06 a.m.
How are the pixels?
or
vtec kicked in y0!1
ultraclyde
ultraclyde SuperDork
8/22/14 8:11 a.m.
I bet THAT made a noise.
volvoclearinghouse
8/22/14 8:19 a.m.
Well, I have a few theories as to why it happened. First, there's this big end bearing / rod end:
IMG-20140821-02216
IMG-20140821-02241
IMG-20140821-02235
But then we've also got this chuck of crankshaft counterweight that broke off (about 30 or 40 lbs):
IMG-20140821-02250
Knurled
Knurled PowerDork
8/22/14 11:46 a.m.
volvoclearinghouse wrote: Industrial application. Turbodiesel, about 170 litre displacement. Threw that rod under load, luckily the oil pressure monitor killed the injectors and shut the engine down. We collected 3 huge boxes of metal shards and debris that I'm sorting through. BTW- each of those rods is about the size of your arm, and weighs about 50 pounds. That metal bench that goes around the side of the engine- see how it's bent? It used to be straight. Rod went straight out the porthole and bent that bench like that.
I bet that made one hell of a kaboom.
Woody
Woody MegaDork
8/22/14 1:38 p.m.
Iceberg?
dculberson
dculberson UberDork
8/22/14 1:49 p.m.
1988RedT2
1988RedT2 PowerDork
8/22/14 2:23 p.m.
Can you get it back up and running this afternoon?
edwardh80
edwardh80 Reader
8/22/14 2:45 p.m.
volvoclearinghouse wrote: Is that serious? IMG-20140820-02198 IMG-20140820-02202 IMG-20140821-02260 Yup.
Not to sound like a gratuitous violence/vandal type, but I love seeing industrial carnage like this. More info and pics please!
TRoglodyte
TRoglodyte SuperDork
8/22/14 2:47 p.m.
If you must fail, be spectacular
KyAllroad
KyAllroad Reader
8/22/14 3:13 p.m.
Glad that wasn't at my workplace. Good luck with repair!
8/22/14 3:29 p.m.
Curmudgeon
Curmudgeon MegaDork
8/22/14 3:47 p.m.
The little guy in there with the hammer was PISSED, wasn't he?
Fueled by Caffeine
Fueled by Caffeine MegaDork
8/22/14 4:07 p.m.
Does that engine have engine journal temp sensing?
SWSsLHmBlcirn9n6sJQfveHD4VQcOXiwZE05oezVjMHD10pQvYUyYNMAzk3DZsdT
