John Brown wrote:From CARS
Well done, sir.
Well done, sir.
93celicaGT2 wrote: What the hell is the "B" for? "Back Up?" "Bimbo?" "Banned?" "Bob Costas?"
It actually stands for "brake." Assuming everything is working correctly, it engages the CVT to do engine braking.
Type Q wrote:93celicaGT2 wrote: What the hell is the "B" for? "Back Up?" "Bimbo?" "Banned?" "Bob Costas?"It actually stands for "brake." Assuming everything is working correctly, it engages the CVT to do engine braking.
UGH.
If i wanted a brake around there, i'd install a Jake Brake.
Come to think of that, that would be pretty awesome.
I still say we need regenerative braking for internal combustion engines that, when applied, turns the engine into a refinery.
Clem
ClemSparks wrote: I still say we need regenerative braking for internal combustion engines that, when applied, turns the engine into a refinery. Clem
Would that be called "Refinerative Braking?"
JeepinMatt wrote: People, it's obvious. It's Skynet.
More like Skynet's quasi-evil cousin. Wants to kill all humans, but instead of being tapped into the defense network its stuck inside of Toyota ECU's.
MrJoshua wrote:JeepinMatt wrote: People, it's obvious. It's Skynet.More like Skynet's quasi-evil cousin. Wants to kill all humans, but instead of being tapped into the defense network its stuck inside of Toyota ECU's.
It thinks Skynet was a bit of an overachiever.
Heard on the news that he pressed the button to shut it down, but it didn't work, so he pressed it again. How much you wanna bet that he didn't hold the button down.
C&D did a test in a V6 Camry I think it was. They said even with the transmission in drive and the the throttle down all the way, they could still get it to stop using just the brakes. It did take a bit longer, but nothing that would require another car to physically slow it down.
That being said, the car should not have behaved in that manner, provided that this story is not a fabrication.
It is amazing how many people, over the years, would bring their car in, say it did thus and such and they are afraid to drive it any more. The dealership says 'fine, leave it.' The owner says 'what about another car?' That's up to the manufacturer. 'What about the payments?' That's up to the bank. 'What about my credit?' See: the bank. In short: they spent too much, wrecked their budget, and want out.
As I said, this stinks all over.
Bobzilla wrote: With no mechanical link to the transmission, no mechanical linkto the throttle plate and minimal mechanical link to the brakes how DO you shut one down?
I dunno..
Mechanical linkages are the best evar...
All of this anti electronic talk is the same stuff that went around the off-road community in the early to mid 90's(in the early internet days)..
Everyone was all in a huff about fuel injection and how complicated it was and you couldn't fix it on the trail and how inefficent it was and WHINE WHINE WHINE WHINE WHINE... Finally one day someone realized that a truck with FI wouldn't bog on hills or wouldn't need to be fixed because it was reliable.. Then people got smart.
This is the same crap that's going around now about the electronic throttle stuff.
Think about the benefits of an electronic throttle. You could have one setting for an autox and one for driving around (with max mpg in mind)... It's not that far off.
Or you could maybe an even more compelling argument is the vintage tractor vs new tractor debates over at www.mytractorforum.com
They go something like this.. The vintage tractor is made to last and will keep running for 50 years... The new tractor does 12x the work of the vintage tractor, runs 24x7, uses 50% the fuel of one vintage tractor, and gives engine overhaul times of 5x the hours of a vintage engine.... (btw.. there's no mechanical connection to the throttle plate on a diesel either... )
Cotton wrote: They're recalling them http://online.wsj.com/article/SB10001424052748704784904575111503873150166.html?mod=WSJ_hpp_LEADNewsCollection
umm.. no they are not.
did you read that article.
ignorant wrote:Bobzilla wrote: With no mechanical link to the transmission, no mechanical linkto the throttle plate and minimal mechanical link to the brakes how DO you shut one down?(btw.. there's no mechanical connection to the throttle plate on a diesel either... )
I didn't think there even is a throttle plate in a diesel. At least there wasn't on my 92 Cummins Ram,but then again that was more like an old tractor than anything built these days.
The guy called 911 and the first thing the dispatcher asked him was if he tried to put it in neutral. His response: "I've never messed with this kind of shifter before, especially while driving. I thought it might flip." What a load of crap. I really hope Toyota pulls the black box data and proves this turd was holding the pedal down himself and only let off when he decided it was time to stop.
I'm not a Toyota fan, but the witch hunt is getting a little ridiculous. Class action lawsuits for diminished value? Screw off, leaches. Your car will still end up with better than average resale value because people are stupid and will forget all this in a year.
Bob
its amazing how many people think that driving down the highway at 70 mph in their soulless econobox is such a delicate balance of traction and aerodynamics that if they do anything different than drive straight ahead, it'll just fly out of control.
one comment on the prius article somewhere else i saw said they'd be afraid to use the e-brake in that situation because it would bypass the abs, lock up the brakes and flip the car.
this was on jalop, btw, so not your average mindless blog commenter, either
also, how did toyota get past the PRNDL requirement?
Mazdax605 wrote:ignorant wrote:I didn't think there even is a throttle plate in a diesel. At least there wasn't on my 92 Cummins Ram,but then again that was more like an old tractor than anything built these days.Bobzilla wrote: With no mechanical link to the transmission, no mechanical linkto the throttle plate and minimal mechanical link to the brakes how DO you shut one down?(btw.. there's no mechanical connection to the throttle plate on a diesel either... )
Diesels don't have a throttle plate.
I also find the story very suspicious. The bit about applying the parking or emergency brake and having it suddenly and miraculously engaging the brakes is quite...interesting. Equally the bit about the throttle pedal "doing something funny". That's not suspicious, the magical self fix that let it all suddenly release when the car got below 50 mph and come to a complete safe non-reving stop (apparently) is.
Do these not have a transmission with an N in it someplace?
Yep, and it's connected to the computer, not the transmission. You make the request for neutral, sending the message to the computer. The computer takes your request under advisement, evaluates the various parameters it considers important, and decides whether or not to honor your request for neutral.
Amazing how difficult this is for some folk to grasp. This is not your old 70's transmission with a lever connected to the hydraulic controls of the transmission itself.
I keep hearing this, but I have never seen an SAE, DOT, NHTSA or agency requirement of this. As far as I know, PRNDL and its variants (there are many) is nothing but a convention. And it never was a rigorously followed convention, there always were, and are, plenty of exceptions.
http://jalopnik.com/5489553/runaway-prius-911-tape-im-over-90
Listen to the call. The guy is obviously sharp as a tack. HA!
ignorant wrote: http://jalopnik.com/5489553/runaway-prius-911-tape-im-over-90 Listen to the call. The guy is obviously sharp as a tack. HA!
911 operator said: Sir can you hear me?
Prius guy said: (Thinking of story....)
> I wonder if he thought of calling 911 before the police caught him speeding. It sounds like anyone in a Toyota can get their speeding tickets thrown out by getting out and kissing the ground when they "Finally" get it to stop.
How about a distilary. It could put the ethenol to better use.
The wendy's finger all over again - this stinks to high heaven. People trying to make a buck off of a semi-legit recall.
I wish this whole Toyota thing would make people realize that our so called "Drivers Training" is one massive joke. Besides that this looks to me like a ringing endorsement for manual trans cars.
