bluej
bluej UltraDork
8/11/17 9:26 a.m.
I need this:
Yes, easy button would be to grind the thread off the end of a regular ol flat head bolt, but this is in a work application and the work to grind it off would be prohibitive for the quantity needed.
Does it exist? other thoughts? I have some other ideas, but figured I'd see what you hardware geniuses (srsly) could come up with.
alfadriver
alfadriver MegaDork
8/11/17 9:30 a.m.
You need what? Is there supposed to be a picture?
There's not even a blank X to me.
bluej
bluej UltraDork
8/11/17 9:34 a.m.
alfadriver wrote: You need what? Is there supposed to be a picture? There's not even a blank X to me.
hmm, that's weird. It's from photoberkit. Anyone else see it?
lets try a link to pic: clicky
8/11/17 9:35 a.m.
Could you have someone put the appropriate Allen bolt in a lathe and turn down the threads?
8/11/17 9:36 a.m.
I can see it. I'll be surprised if you can get that off the shelf. Looks kind of like a Samurai's shifter locator pin.
tuna55
tuna55 MegaDork
8/11/17 9:39 a.m.
Appleseed wrote: Could you have someone put the appropriate Allen bolt in a lathe and turn down the threads?
That's probably the best bet. I don't think it's a standard thing, though like Gameboy said, other manufacturers have solved that problem with custom hardware before, depending on how sourcing works and what size/specs you need.
ProDarwin
ProDarwin PowerDork
8/11/17 9:43 a.m.
How many do you need? I have seen similar hardware before, but I don't think you'll find it off the shelf. You probably just want to talk to a hardware manufacturer and make your own. Or find an alternative way of accomplishing what you need.
T.J.
T.J. MegaDork
8/11/17 9:49 a.m.
Search for dog point bolt or dog point screw.
How long does the pin need to be and is this a bolt or more of a wood screw?
Seems that something like this is usually inserted from the side that the pin is on, then it would be something more like a screw in dowel.
4cylndrfury
4cylndrfury MegaDork
8/11/17 9:53 a.m.
There is a pic on Berkit. If youre not seeing it, here is a link
http://216.92.53.23/photoberkit.com/copper/albums/userpics/10017/IMG_20170811_092012431.jpg
Bluej, Ive seen those before, but they were always in a bag of hardware that came with something. IDK where you could find them off the shelf. Sorry, I know thats not much help.
Depending on your machining skills and tool availability, I could see setup where you have a cylindrical slug of steel, with a hole thru the center, tapped to accept an off-the-shelf flathead machine bolt. If youre using 2" screws, the cylinder would need to be 1.75" tall, so that a quarter of an inch is protruding. Tighten the screw into the slug, and chuck it in a lathe. Grind off the thread, and boom.
No Lathe, you could chuck up the screw, threads first, in a drill press, and grind quickly with an angle grinder, then cut off the threaded end with a cuttoff wheel.
Either way, you could probably churn out 2-3 a min if you had to. Not sure how many you would need? A few dozen would be possible in a short amount of time, but if you need hundreds or more, youre right, probably time prohibitive. Also, the lathe route would make the pin-end dims repeatable. Obviously, hand grinding with a grinder would not be as exact.
bluej
bluej UltraDork
8/11/17 9:55 a.m.
T.J. wrote: Search for dog point bolt? How long does the pin need to be and is this a bolt or more of a wood screw?
Ooh! that could work! Quick search of dog point bolts is promising.
It's a bolt. Here's a sketch of what the need is. There's a frame of aluminum tube and I need to hold the acrylic panels in place w/ minimal visible hardware. The pin portion only needs to be ~ 1/4" long.
I would consider the qty needed a fair amount for the types of things we usually design. Definitely more than 100 but less than 1,000 of these fastening points.
bluej
bluej UltraDork
8/11/17 9:57 a.m.
also, having the fastener head proud of the tube is pretty undesirable, hence the flat-head.
thanks for the thoughts all, helps a lot!
alfadriver
alfadriver MegaDork
8/11/17 9:57 a.m.
So a dumb question- what's the need for the extension? Is it specifically for shear strength and alignment, or just one of those?
OR is it so that it's easier to install- since the extension can be located in the hole?
If it's the last part- there are bolts that prevent cross threading out there- which also have a similar extension.
edit- I see the clarification
bluej
bluej UltraDork
8/11/17 10:03 a.m.
This might be a winner. The fabricator could weld internally threaded rod into the tube, then thread these all the way through. I think the tip would be just long enough:
Mcmaster is life
ultraclyde
ultraclyde PowerDork
8/11/17 11:12 a.m.
Most acrylic I've seen like this (typically signage applications) would be retained by a small C channel that was internally screwed to the square tube above. This also helps account for less than perfect edges on the acrylic if necessary. Would that work? What is it that you're making here?
bluej
bluej UltraDork
8/11/17 11:21 a.m.
ultraclyde wrote: Most acrylic I've seen like this (typically signage applications) would be retained by a small C channel that was internally screwed to the square tube above. This also helps account for less than perfect edges on the acrylic if necessary. Would that work? What is it that you're making here?
I can share after mid December
For aesthetic reasons, no extra capture channel here.
the_machina
the_machina New Reader
8/11/17 12:02 p.m.
What you're looking for is DIN 925. See this sheet: http://www.newfastener.com/wp-content/uploads/2013/03/DIN-925.pdf
T.J.
T.J. MegaDork
8/11/17 12:27 p.m.
In reply to the_machina:
I think you nailed it!
bluej
bluej UltraDork
8/11/17 12:32 p.m.
the_machina wrote: What you're looking for is DIN 925. See this sheet: http://www.newfastener.com/wp-content/uploads/2013/03/DIN-925.pdf
you sir, get ALL the cookies for today! THANK YOU!!
xm8hdCurYBzWNskPxwqpqWVgSBOvDQkQSJrriGeYvTCrEk3b6pJn2lAn3dhYJcGX
