Stampie
Stampie MegaDork
8/8/21 7:14 p.m.
I need some with an ID of 1/2 inch and an OD of 5/8 or for those smarter than us Americans ID 13mm and OD of 16mm.  I can't find that at all.  Seems they all have "wall" thickness of at least 1/8 inch.  Am I hunting an unicorn?
759NRNG
759NRNG UberDork
8/8/21 7:26 p.m.
Sorry I'm not at all familiar with "peelable" please esplain in greater detail at your earliest convenience and don't expect a response before sunrise vato.....late
Stampie
Stampie MegaDork
8/8/21 7:27 p.m.
In reply to 759NRNG :
Basically very thin washers that are stuck together.  Used when you want to say index something that's being threaded on.
Yourself
Yourself New Reader
8/8/21 7:48 p.m.
Searched on "shim washers" and got several hits. Closest seems to be on ebay "ARRMA Washer 13x16x0.2mm (4) - ARA709031".  Could not copy link for some reason.
Stampie
Stampie MegaDork
8/8/21 7:53 p.m.
In reply to Yourself :
Thanks.  Those might work.
Wally (Forum Supporter)
8/8/21 7:57 p.m.
I read this as peeable washers. I had a different set of questions
Stampie
Stampie MegaDork
8/8/21 8:06 p.m.
In reply to Wally (Forum Supporter) :
8/8/21 8:16 p.m.
In reply to Stampie :
I don't know if I've ever experienced PTSD before but I'm having flashbacks to my last visit to the Cheesecake Factory
preach (fs)
preach (fs) HalfDork
8/8/21 9:02 p.m.
We use peelable stock at work. Comes in 0.125" sheets and each peel is ~0.002". Those that cry about a paper cut need to see the real hell.
Yourself
Yourself New Reader
8/8/21 9:28 p.m.
Mr_Asa
Mr_Asa PowerDork
8/9/21 1:35 a.m.
I have never heard of these.  That's neat.
JFW75
JFW75 New Reader
8/9/21 4:00 a.m.
Used to use the peelable stock for shims doing gearbox and motor alignments on very large equipment. Beat grinding spacers to thickness 8-10 times for each mounting foot.
8/9/21 6:52 a.m.
Put a nut in a lathe, run a mating bolt through a 1/2" washer, tighten it down and turn to the diameter you need.
slantvaliant (Forum Supporter)
slantvaliant (Forum Supporter) UltraDork
8/9/21 6:56 a.m.
Also used to index muzzle devices.
Stampie
Stampie MegaDork
8/9/21 7:03 a.m.
Bingo except someone that shall not be named had a barrel cut down then threaded.  That same someone forgot about the adjustment screw on their gas block extending out 1/2 inch past the threads.  That same someone now needs a customized muzzle brake and .625 washers to index it because a crush washer is too big.
stafford1500
stafford1500 Dork
8/9/21 7:10 a.m.
Once you get your numbers worked out you could REQUEST someone turn the part you need...
Stampie
Stampie MegaDork
8/9/21 8:08 a.m.
In reply to stafford1500 :
I know but looks like $3 off the shelf stuff will work so that's not worth asking for.
RTImwCCs1ekYeYPfJuziUoEVkk6x7dunSY3KuZzyT7iZHsH05GFcEamOjkyuVRFg
