BoxheadTim
BoxheadTim MegaDork
2/12/23 9:51 a.m.
So for the last few months I've had an unexplained (tidal?) pool in the mechanical room of our house. It's not sunny or deep enough so my wife could use it as a therapy pool for her Watsu work, and I can't stock it with fish either. Ideally, I would prefer if it just went away and never came back, rather than having to regularly mop the floor.
The problem is that is seems to be close to impossible to find the source of the leak. Both the plumbers who have done other good work on the house before and myself suspect that it's somehow an issue with the water filtration system, but it seems to be a Heisenbug in the sense that it doesn't seem to occur when someone is watching. I have cups under all the drains/overflows that I would normally expect to leak like the hot water emergency overflow/pressure relief and the overflow for the water softener's brine tank. They're all bone dry, of course, no matter how much water ended up on the floor.
The plumber suspects that it might be a defect in one of the cylinders that are part of the water filtration system - one air separator for the air injection system that looks a bit like a welding gas cylinder and is metal, and two fibreglass ones that are for the softener and PH neutralizers. Neither of the three leaks in normal operation or when I run the backwash cycles and observe it. The problem does seem to happen overnight as I usually check the mechanical room in the morning and evening at the moment and it's normally dry. I've been trying to figure out the pattern of the problem appearing, but so far I'm drawing a blank.
Right now the main problem I have is that it seems impossible to figure out exactly which part is leaking. Firing the part cannon at the mechanical room - as much as I would like to do that, because I don't agree with some of the decisions they made when configuring the house - is a very expensive prospect with uncertain outcome, so better to be avoided for now.
Which leaves me with the question - how on earth do I figure out where the leak is coming from before everything in the mechanical room gets damaged by the extra water baths?
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) Dork
2/12/23 10:27 a.m.
Is this mechanical room in a basement?  Could it be water seeping in from the ground?  Maybe a picture will help.
bentwrench
bentwrench UltraDork
2/12/23 10:30 a.m.
Get up at 3 AM on a cold night and go out there with a flashlight.
2/12/23 10:47 a.m.
Maybe line the floor with brown paper and if you check it enough you will spot a "trail" to the source.
BoxheadTim
BoxheadTim MegaDork
2/12/23 10:53 a.m.
In reply to Purple Frog (Forum Supporter) :
It is in the basement, but it's been dry for most of the 4 years we lived here. When I went down to start mopping up and taking photos, it looks like I found the issue. Or at least an issue that's contributing.
Turns out the drain valve for the pressure tank is leaking. I think it was an intermittent leak but I had to drain the pressure tank yesterday as I was servicing the UV light in the system and used that an as excuse to drain at least some of the sediment out of the tank. That must've been enough to tip things over the edge and turn an intermittent leak into a continuous leak.
Looks like I'll call the plumber tomorrow to see if/when they can come out to replace it. Yes, I could do it myself but given the potential for mayhem and no water if it goes wrong, I'd rather let the pro deal with it.
BoxheadTim
BoxheadTim MegaDork
2/12/23 10:54 a.m.
I'll definitely keep the brown paper idea in mind if this happens again.
OHSCrifle
OHSCrifle UltraDork
2/12/23 4:13 p.m.
Whenever I make a new solder joint or other plumbing connection I leave paper towels under the stuff for a few days to confirm no drips. This also helps to locate a drip.
I agree with Purple Frog - Need more info about this room to try to diagnose.
MtRCp79Z08X8nwqlGAJchNMpui3Mh9ynfYorpqYHn9Xhy90OX1RtliTGVS6OYI2t
