D2W
D2W HalfDork
11/13/18 12:30 p.m.
I have a bathroom in the house that has some paint peeling. (Insert bathroom joke here). Its a few small spots, but it is both the paint and texture. Is using some texture in a can to fix the small spots, and then repainting the whole bathroom acceptable? Or do I need to do more?
jharry3
jharry3 Reader
11/13/18 12:36 p.m.
Its what is acceptable to SHMBO.   laugh
If you can match the texture locally it will be fine.   That is usually the challenge.
dculberson
dculberson UltimaDork
11/13/18 12:43 p.m.
To prevent further peeling, try scraping back what's there to get the loose stuff off then put a coat of a bonding primer on. (Ie, Kilz Adhesion.) We had paint peeling off in sheets in our garage when we bought the place, and the painter did that and we haven't had a single peel since, in four years.
11/13/18 1:49 p.m.
First find out why it's peeling, moisture?  You mention texture, like a popcorn ceiling?
My front living room has square tiles on the ceiling, pressed cardboard from the 1950s.  I replaced it with plastic tiles, also did it on my side porch where moisture hangs out, no more stained ceiling.
D2W
D2W HalfDork
11/13/18 1:55 p.m.
In reply to 914Driver :
Bathroom, 4 kids, yes plenty of moisture. The texture is just wall texture behind the paint.
I think I scrape and texture a spot to see how it looks.
11/13/18 2:24 p.m.
Put down some BIN paint for primer.
Antihero
Antihero Dork
11/13/18 2:28 p.m.
I usually have the texture in a can stuff because it doesnt always work but i think its best for this situation
Ki9gHfhgzvkUplqj9Zu1vjp56ydNTrY5ZyKMM88UpitD4H07ZxGUALwfZRstYoeH
