Noddaz
PowerDork
2/16/25 1:40 p.m.
Anyone in the hive have a solution for this? It is easy to find fixes online, but after numorus changes to setting the problem persists.
I am currently 6 feet from my home router and see the wifi turn on and off. This happens everywhere, it is not a router issue.
It looks like it's been a known problem with the S22 for some time, do you have the latest OS update and Google Play version installed? That may not fix it but it's a good place to start, Samsung is definitely aware of it. Looks like some common changes that have yielded some success are disabling the intelligent wifi options + wifi calling or doing a network reset in settings.
I have some sort of Samsung, and it matters not a whit where I put the router antenna in my house, it will not stay on wifi when I'm in the half bath off my bedroom. A magic dead spot, somehow.
In reply to Streetwiseguy :
Maybe a sheet of metal between the two (maybe a big mirror?), especially if it's closer to the router. I once heard of a guy who had a separate outdoor-only wifi AP hosted by putting the router near the peak of the house's roof with a small piece of metal below it that prevented the signal from reaching anywhere inside the house but allowed access from outside.
My S21 did the same thing. I really have come to dislike the last two Samsungs I had so I switched back to a Pixel and I'm loving life. I know that's not an answer to your question, but just letting you know you're not the only one.
My house has foil-backed drywall on the exterior walls. I had my WAP on one of these walls, and our TV would get kicked off of the Wi-Fi all the time, requiring a reboot to reconnect. The TV was only 10 feet away , and was installed on the same wall. Moving the WAP from that wall to the core of the house helped. I think the signal was being reflected off of the foil backing and this was causing interference. To this day, having the TV on that wall is not an issue--it seems like the problem was that the WAP was on that wall. Where is your WAP/router installed? If it's along an exterior wall, consider moving it if you can, at least temporarily, to test it.
Noddaz
PowerDork
2/17/25 5:30 p.m.
In reply to confuZion3 :
My router is on an outside wall. But the problem can happen anywhere, on any system. Work, home, the mall, public library.
