Chadeux
Chadeux Dork
9/4/17 1:57 p.m.
white_fly
white_fly Reader
9/4/17 2:03 p.m.
Better aesthetics than the Exocet!
Mike
Mike SuperDork
9/4/17 2:20 p.m.
I'm not sure where I'd actually get to use it, but it looks great.
KyAllroad
KyAllroad PowerDork
9/4/17 3:04 p.m.
Bolt on some slicks, find a bike motor with some cajones and go autocrossing!
Patrick
Patrick MegaDork
9/4/17 4:01 p.m.
I want that. How big an engine can we fit in place of the 1 cylinder 150?
Chadeux
Chadeux Dork
9/4/17 4:24 p.m.
In reply to Patrick:
I'm thinking something Banshee flavored for some reason.
einy
einy HalfDork
9/4/17 5:43 p.m.
In reply to white_fly:
Not to my eye, but I might be biased.
9/4/17 5:47 p.m.
How much would the hospital bill be?
singleslammer
singleslammer PowerDork
9/4/17 6:04 p.m.
A Honda XR 650r motor should slot in and that is 50 hp out of the box with a lot more on tap.
mndsm
mndsm MegaDork
9/4/17 6:42 p.m.
Patrick wrote: I want that. How big an engine can we fit in place of the 1 cylinder 150?
How big is a 13b?
dean1484
dean1484 MegaDork
9/4/17 6:44 p.m.
How big is a 13b?
That is exactly what I was thinking.
Patrick
Patrick MegaDork
9/4/17 7:49 p.m.
singleslammer wrote: In reply to Patrick: A Honda XR 650r motor should slot in and that is 50 hp out of the box with a lot more on tap.
Ouch, one of those is as much as the kart.
I'm thinking more power, formula fordish size tires, etc... then swap back to atv tires to play
gearheadmb
gearheadmb Dork
9/4/17 8:25 p.m.
I read the title and came here expecting to hate it. I definitely don't hate that. I hope they sell a bunch of them and then they sell for cheap when they break down, you know,just like the Chinese four wheelers. Because these would be worth rebuilding with quality components.
Chadeux
Chadeux Dork
9/4/17 10:49 p.m.
The only issue I see with it is the rear axle. It looks like the whole drivetrain is on a hinged cradle. Which I just don't like in general. Plus it looks like they cheaped out and the rear axle ended up being something off the shelf and the track is way narrower than the front axle. I see potential though.
Knurled
Knurled MegaDork
9/5/17 5:18 a.m.
How big is a snowmobile engine?
Brian
Brian MegaDork
9/5/17 5:56 a.m.
Looking into it, it seems to be an Ariel styled adult sized go-cart. I like it, but I don't think I would try to engine swap it without reengineering EVERTHING about it.
AWSX1686
AWSX1686 HalfDork
9/6/17 2:39 p.m.
Depending on how much you want to modify things, and if you don't mind giving up reverse, I think a 4 cylinder sport bike motor would be very doable. I guess since it's not meant for street it probably wouldn't qualify for the challenge though....
jstand
jstand HalfDork
9/6/17 9:12 p.m.
You can get over 100 HP with less than 600cc if you go with a liquid cooled.
They are pretty compact if you go liquid cooled.
That fan cooled  are bigger, due to fins, but don't require any external cooling. Unfortunately they have about 1/2 to 2/3 the hp of the same sized liquid cooled.
Woody
Woody MegaDork
9/6/17 9:23 p.m.
My biggest fear is that the chassis is made out of recycled electrical conduit.
BrokenYugo
BrokenYugo MegaDork
9/6/17 11:58 p.m.
If the back half weren't made of crappy GY6 go kart bits they might have something there.
dculberson
dculberson PowerDork
9/7/17 10:07 a.m.
I feel like I could put a hitch receiver on that and make a compelling case for using one with my landscape trailer around the yard.
ProDarwin
ProDarwin PowerDork
9/7/17 10:45 a.m.
I don't like *that* thing, but looking at it, I'm sure with some tweaks they could make something pretty cool for roughly the same cost.
Patrick
Patrick MegaDork
9/7/17 7:56 p.m.
I'm going to wait for one to come up on CL that quit running in a year or so.  Hopefully that happens, because at $500ish it's worth playing with.  Maybe by that time i will find a rear ended 1.0 ecoboost fiesta at auction.
BrokenYugo
BrokenYugo MegaDork
9/7/17 9:51 p.m.
In reply to Patrick :
Those GY6 engines have a tendency for the exhaust valve to tighten up until it quits running under load (OHC design with tight lash specs), so a year or so might be an accurate projection.
nEvh2CJz9PFpMCtzUyY8ONau7wdeCqEZ3yStxi31i9Jhxj36PJ6FLxOFyCvtZzx7
