Grtechguy
Grtechguy MegaDork
3/13/16 4:28 p.m.
Now...what do you folks use to get into tight corners? Looking for tools/cleaning solution ideas. everything so far was done with a soft wire brush on a 4.5" angle grinder.
Woody
Woody MegaDork
3/13/16 5:00 p.m.
Naval jelly.
EvanB
EvanB UltimaDork
3/13/16 5:06 p.m.
Tube brush in a drill?
http://www.amazon.com/Weiler-Power-Brush-Double-Spiral/dp/B007O1F4XG
EvanB
EvanB UltimaDork
3/13/16 5:22 p.m.
I would use one of these with a surface conditioning belt just because I have a couple of them. There are definitely cheaper options.
Maybe a strip of surface conditioning material if you have easy access to the back side to pass it through and pull it back and forth.
I also think I have some of these laying around if you want me to send you one.
ncjay
ncjay Dork
3/13/16 5:30 p.m.
http://www.eastwood.com/ew-buff-kit-and-metal-protect-14-oz-aerosol.html If that isn't right, there's always Dremel tools.
stuart in mn
stuart in mn UltimaDork
3/13/16 6:10 p.m.
Using wire wheels and abrasive belts have probably removed any chrome that was on there...I'd use something like Evaporust or one of the home brew methods for removing rust like a molasses bath.
octavious
octavious HalfDork
3/13/16 6:39 p.m.
Aluminum foil and water or vinegar.
Don't laugh it works great and will get all those hard to reach places.
Dr. Hess
Dr. Hess MegaDork
3/13/16 6:40 p.m.
That's probably not chrome. Well, technically, I suppose it may be a certain percentage chrome, but not "chrome" in the automotive sense of the word. That's probably stainless steel.
4arrSmHuqzDEcx0EhOuLJlCT8ppqn1L1dHfJsUGVwdU8wH4IgEUO4vza0h7qrr0E
