I drove my subs a little too hard
Fortunately, I think its fine, but the surround came unglued from the basket. Instead of buying a new one I'd like to try repairing this one. What glue should I use? It is a Santoprene material and the basket is painted steel (or maybe aluminum...I'll have to check)
I'd check here: DIY Mobile Audio
It's basically the GRM of car audio forums. There are a few guys that repair/rebuild speakers, and they've posted build logs of their work.
I've repaired blown out speaker cones with nail polish. Dunno if that would apply to your problem or not. The repair was successful and I couldn't tell the difference in the sound between the repaired one and the original one.
I've used Shoe Goo from Walmart to repair a cone to surround separation. It should work between basket and surround just as well
I used to re-cone drivers professionally. Dont use Elmer's glue. The eBay kits include a glue that looks like, and could be, Elmer's. It wont hold over time. Elmer's can be used to adddampening and to prevent 'flappong' only. I don't know the type of glue we used, sorry. Too many hears in a confined space with said glue I think.
When you do find the glue, shoot me a IM. I'll give you some pointers that will help. Dont remove the dust cap, I have a trick for that too.
Someone said Loctite 411. I thought that was a cyanoacrylate super glue. Wouldn't that just vibrate to dust?
curtis73 wrote: I drove my subs a little too hardFortunately, I think its fine, but the surround came unglued from the basket. Instead of buying a new one I'd like to try repairing this one. What glue should I use? It is a Santoprene material and the basket is painted steel (or maybe aluminum...I'll have to check)
Good man!
The stuff that I used on my surround repair was kinda like rubber cement. It came with my repair kit from www.simplyspeakers.com
Front says, "speaker repair adhesive #MI-3035. All it says on the back is that it contains Toluene, Hexane, and Rubber Solvent. Also warns against getting any on your hootus.
