z31maniac
z31maniac UltimaDork
10/8/14 7:48 a.m.
Since it's nearly certain we will be moving there next year, I need to know the car laws regarding "enthusiast" type modifications.
OK is basically a free for all. No inspections, no emissions testing, no nothing. You can basically do as you please.
I suspect Texas isn't the same? Can anyone enlighten me?
Nick_Comstock
Nick_Comstock PowerDork
10/8/14 8:05 a.m.
I know of a safety inspection. My area (Temple)doesn't do emission testing but I'm not sure about other areas.
Thinkkker
Thinkkker UltraDork
10/8/14 8:08 a.m.
If new enough you can get a OBDII test. they will plug in and make sure your computer throws a code and reads right. Even with a tuner you can pass.
Some places will put the car on a dyno, but not all.
bmw88rider
bmw88rider HalfDork
10/8/14 8:27 a.m.
Well....What county are you looking at? There is different laws depending on if it's an emissions county or a non emissions county.
The general safety inspection is pretty straight forward. You need to have the following:
05.01 Inspect Every Passenger Car For: (Listed in suggested order of inspection)
  • Check for evidence of Financial Responsibility
  • Horn
  • Windshield Wipers
  • Mirror
  • Steering
  • Seat Belts
  • Brakes (system) (Parking - beginning with 1960 models)
  • Tires
  • Wheel Assembly
  • Exhaust System
  • Exhaust Emission System (beginning with 1968 models)
  • Beam Indicator (beginning with 1948 models)
  • Tail Lamps (2); (1) if 1959 model or earlier
  • Stop Lamps (2); (1) if 1959 model or earlier
  • License Plate Lamp (1)
  • Rear Red Reflectors (2)
  • Turn Signal Lamps (beginning with 1960 models)
  • Head Lamps (2)
  • Motor, Serial, or Vehicle Identification Number
  • Gas caps on vehicles 2-24 model years old
  • Window Tint.
If you live in an emissions county then you have to pass the ODB2 test or the sniffer test on cars up to 24 years old.
z31maniac
10/8/14 8:40 a.m.
Not sure exactly which county yet, but if I had to guess, I'd say Dallas county.
bmw88rider
bmw88rider HalfDork
10/8/14 8:57 a.m.
Dallas county and all of the counties that touch it are emissions counties so anything 1990 and newer currently do need to pass emissions testing.
http://www.txdps.state.tx.us/rsd/vi/inspection/inspectionCriteria.aspx
That link may help you a little bit.
z31maniac
10/8/14 9:18 a.m.
Thank you very much for the link!
Makes me wonder if a BRZ with one aftermarket cat would pass the sniffer test.
btp76
btp76 Reader
10/8/14 9:43 a.m.
There is a rolling 25 year exemption from emissions testing. Also, at 25 years you can get antique tags and be inspection exempt. 96 and newer are basically a plug in. At cooperative stations if you have no CEL you'll pass. Pre 96 but newer than 25 years go on the dyno with a sniffer in the tailpipe, but that window, in a few months, will only be 5 years.
Ojala
Ojala HalfDork
10/8/14 12:31 p.m.
In reply to z31maniac:
BRZ wouldnt get a sniffer test. They only do that on pre-OBDII cars <25 years. The BRZ would get the OBD test for emissions and the safety inspection.
z31maniac
10/8/14 1:18 p.m.
Ojala wrote: In reply to z31maniac: BRZ wouldnt get a sniffer test. They only do that on pre-OBDII cars <25 years. The BRZ would get the OBD test for emissions and the safety inspection.
Excellent, thanks for the info!
wbjones
wbjones UltimaDork
10/8/14 6:24 p.m.
z31maniac wrote: Thank you very much for the link! Makes me wonder if a BRZ with one aftermarket cat would pass the sniffer test.
if it's like other places, you won't be offered the option … '97 and newer are all hooked up to the OBDII port
edit: Ojala beat me to it
Ojala
Ojala HalfDork
10/8/14 8:31 p.m.
If you want to title a rebuilt or a project car let me know and I can give you the low down. Dallas is a pain to work with. Fortunately I am friends with the guy, Pete, that is THE official inspector in tarrant County.
mazdeuce
mazdeuce UberDork
10/8/14 9:27 p.m.
I'm in Houston, but I'm subject to the same basic rules. It's actually getting easier as time goes on because of the rolling exemption. With an OBDI car on the rollers you never quite know what's going to happen. This sucks. With OBDII cars you can plug in a scanner before you go and it it reads clean and ready you know you will pass. Right now the window for roller cars is only 90-97. Next year it's 91-97. You can modify the ever loving E36 M3 out of an OBDII car as long as it reads ready and passes the safety checks.
xOPxCyWDT6p0shw9duJwIFyYC4abs3GnjI8UTyWoEoCcdAjBpfJ2Egoq7A3bdWaI
