carguy123
carguy123 UltimaDork
8/6/13 7:23 p.m.
I've heard of this technology for years, but I didn't realize it was this close to being on cars.
This isn't a fluff piece so get to your quiet place and see what Koenigsegg is doing. It looks like a ratty old Saab.
30% more on 50% less.
Smaller, more compact engines. Shorter in height & in block length plus you might be able to make a cylinder disappear to make it even more compact.
infernal combustion
stroker
stroker Dork
8/6/13 7:25 p.m.
I saw that a few months ago. Pretty cool. Looks expensive, though.
fanfoy
fanfoy HalfDork
8/6/13 7:35 p.m.
They've been using that on F1 engines for a few years now. I wounder how long before someone makes a version for a production car engine. There are a lot of reliability aspects to overcome, but it seems like the way forward.
ProDarwin
ProDarwin SuperDork
8/6/13 10:35 p.m.
Really cool. Hope that makes it into production cars soon.
What provides the air pressure?
Trans_Maro
Trans_Maro UltraDork
8/6/13 10:51 p.m.
In reply to ProDarwin:
If they're considering building an engine around this technology, it wouldn't be hard to dedicate a couple cylinders as the air compressor.
Very cool stuff.
Anti-stance
Anti-stance UltraDork
8/7/13 6:47 a.m.
That is rad.
alfadriver
alfadriver PowerDork
8/7/13 6:52 a.m.
fanfoy wrote: They've been using that on F1 engines for a few years now. I wounder how long before someone makes a version for a production car engine. There are a lot of reliability aspects to overcome, but it seems like the way forward.
That's not what they use on F1 cars. On F1 cars, the springs are compressed air- the valves are still actuated by cam shafts and lobes. This replaces all of that.
RossD
RossD PowerDork
8/7/13 7:02 a.m.
Can I get the Cliff notes?
alfadriver
8/7/13 7:07 a.m.
RossD wrote: Can I get the Cliff notes?
Basically, the system replaces cam shafts and valve springs for a compressed air actuator (much like an injector) for the valves. It's an interesting system, but there are some interesting things that need overcome.
Great for an ideal case. Not sure about when a car is left overnight at -20F....
GameboyRMH UltimaDork
8/7/13 7:22 a.m.
Infernal combustion engine? This isn't about turbo rotaries
Zomby Woof
Zomby Woof PowerDork
8/7/13 7:29 a.m.
Designs and prototypes like this have been around for many years. It would be incredible if they work, but nobody has figured it out yet. I think the speed, weight, and sheer number of cycles are a problem. I won't stop grinding cams just yet
Sorry, but every time I hear Koenigsegg, I think of this track day video
Adrian_Thompson
Adrian_Thompson UberDork
8/7/13 7:31 a.m.
GameboyRMH wrote: *Infernal* combustion engine? This isn't about turbo rotaries
No, they are external combustion as they go BANG!
4cylndrfury
4cylndrfury MegaDork
8/7/13 7:55 a.m.
Zomby Woof wrote: Designs and prototypes like this have been around for many years. It would be incredible if they work, but nobody has figured it out yet. I think the speed, weight, and sheer number of cycles are a problem. I won't stop grinding cams just yet
It appears from the video that they do at least have a fairly long term test underway, and thousands of Km's worth of testing already completed and recorded. I agree, its probably not ready for the open market, but I think to say "no one has figured it out" or "it doesnt work" is a bit short sighted. They seem to have the speed and cycling figured out (based on the lab demo in the video anyway).
iceracer
iceracer UberDork
8/7/13 8:03 a.m.
There have been lots of prototype engines introduced over the years but for various reasons, durability, cost, etc. none have yet beaten the old internal combustion engine. Just think, a 200 ci-40 hp. engine has now morphed into a 61 ci. 140 hp. engine. Broad resemblance but just goes to show how things have progressed. there's life in the old girl yet.
93EXCivic
93EXCivic MegaDork
8/7/13 8:06 a.m.
So which one of you nuts is going to make a home brew version of that?
Zomby Woof
8/7/13 8:09 a.m.
In reply to 4cylndrfury:
Maybe coming to that conclusion from watching a 10 minute promotional video is a little shortsighted
Awesome technology. I'll be a believer when I see it in production
pinchvalve
pinchvalve UltimaDork
8/7/13 8:11 a.m.
I think replacing the air with an electro-magnetic system might solve some more problems. If GM can make the fluid in their shocks react based on current, the technology can't bee too far off.
4cylndrfury
8/7/13 8:28 a.m.
Zomby Woof wrote: In reply to 4cylndrfury: Maybe coming to that conclusion from watching a 10 minute promotional video is a little shortsighted Awesome technology. I'll be a believer when I see it in production
JoeyM
JoeyM Mod Squad
8/7/13 8:36 a.m.
[sigh] And here I was thinking that this would be about a new FUNCTIONAL version of ceramic block , 6-stroke engines.
cwh
cwh PowerDork
8/7/13 8:43 a.m.
I think a very interesting possibility with this system is the ability to change "Cam" timing. Granny style when wanted, aggressive when desired. Change the entire personality of the engine to match the needs.
RossD
RossD PowerDork
8/7/13 8:58 a.m.
cwh wrote: I think a very interesting possibility with this system is the ability to change "Cam" timing. Granny style when wanted, aggressive when desired. Change the entire personality of the engine to match the needs.
Don't forget to the dynamic capabilities of the engine with regards to boost and fuel octane.
alfadriver
8/7/13 9:04 a.m.
pinchvalve wrote: I think replacing the air with an electro-magnetic system might solve some more problems. If GM can make the fluid in their shocks react based on current, the technology can't bee too far off.
that version of valve actuation has been around for longer than this compressed air version. While it seems easy and straight forward, it turned out to not be. This is a different version of that.
The problem is that there some basic electrodynamic physics that means it takes a lot of electricty to move the valves and still manage to either overcome the valve spring or hold the valve to seal. It's a pretty interesting problem. Bear in mind, the electric change in shocks isn't actually changing the location, just altering the valving or mildly chaning the fluid properties. It's not moving the entire corner- so it takes a lot less energy to do that.
In the long run, which system can supply enough energy to open and close the valves fast enough, and still supply enough holding pressure to keep the valves closed- that's going to be the winner.
alfadriver
8/7/13 9:06 a.m.
that's a very, very deep rabbit hole. VCT adds an interesting variable. variable valve actuation is HUGE in terms of the added variables.
Mezzanine
Mezzanine Reader
8/7/13 9:06 a.m.
iceracer wrote: There have been lots of prototype engines introduced over the years but for various reasons, durability, cost, etc. none have yet beaten the old internal combustion engine. Just think, a 200 ci-40 hp. engine has now morphed into a 61 ci. 140 hp. engine. Broad resemblance but just goes to show how things have progressed. there's life in the old girl yet.
It's still an internal combustion engine- it's just using a different method to open the valves.
I imagine back in the old days when we were all running flat heads and pushrods, everyone on the forums said the same thing about overhead cams.
Beer Baron
Beer Baron UltimaDork
8/7/13 9:06 a.m.
In reply to iceracer:
This is still an internal combustion engine. It just uses a a computer controlled pneumatic system instead of a mechanically controlled cam shaft to actuate the valves. Sort of like EFI replacing carbs.
Similarly, the ability to have map precise valve opening time, height, and duration for a given rpm and load could be huge.
Zf9E7OrrQZ5gPRsDSWMqDquHxzb5RS3Z7dtYwY83zOeLBBKgIJ3flulbxfmNRXpL
