Jake
Jake HalfDork
10/11/09 9:33 p.m.
http://www.skyhawg.com/sam1.html
Air cooled V-twin powered Samurai.
mad_machine
mad_machine SuperDork
10/11/09 10:49 p.m.
I wonder if using a rubber guibo to connect the engine to the trans would have worked better than the always breaking U joints?
orphancars
orphancars New Reader
10/11/09 11:21 p.m.
Probably putting some degree of misalignment/angle into that u-joint would probably help as well -- it looks like it is a straight shot from the output of the motor to the input of the trans.
DrBoost
DrBoost HalfDork
10/12/09 5:34 a.m.
Looks wild. I'd like some vids. I'd also think the cooling system should blow from the front, that way it can be used while crawling down a trail and it won't be fighting the air coming in from the grill.
ManofFewWords
ManofFewWords Reader
10/12/09 8:04 a.m.
Those motors are not cheap. Around 4g's I think.
Xceler8x
Xceler8x Dork
10/12/09 8:11 a.m.
To me it looks like he's using the original blower motor for the heating system to create his engine cooling system.
Well, the guy used available resources to fix a problem. I commend that. Now he has to buy two less of everything. Two less spark plugs, two less spark plug wires..
cwh
cwh Dork
10/12/09 8:23 a.m.
The guy builds airplanes. He turned his input shaft on his own lathe. Obviously a highly skilled fabricator , with all the toys , and the time and money to do any damn thing he wants to. Meticulous. We all need friends like this.
mad_machine
10/12/09 8:32 a.m.
I want videos too. I wonder how it sounds.. V twins are a bit obnoxious when bolted to harleys, it must be quite a head turner in a sammy
GameboyRMH SuperDork
10/12/09 9:14 a.m.
DrBoost wrote: Looks wild. I'd like some vids. I'd also think the cooling system should blow from the front, that way it can be used while crawling down a trail and it won't be fighting the air coming in from the grill.
+1 cooling is gonna be a major issue, especially when offroading...cool swap though. It'll really feel like a quad now!
914Driver SuperDork
10/12/09 9:14 a.m.
Got torque?
mad_machine
10/12/09 3:33 p.m.
more than the stock sammy
TlyAsVOAWCMfPEaCPmrtSqz4WJsPgncqhUUD5V7Avepj9G4PfFdeblKpXhAG4BdS
