glueguy
glueguy Dork
5/31/18 9:02 p.m.
Why do I have this trap type plumbing in the hvac condensate drain line from the AC unit? What purpose does it serve?
Cousin_Eddie
Cousin_Eddie HalfDork
5/31/18 9:04 p.m.
I don't know where you're at, but here in Texas it would keep scorpions from climbing up the line into your house.
Ian F
Ian F MegaDork
5/31/18 9:05 p.m.
I've been told it's to keep insects out of the coil space.
dropstep
dropstep SuperDork
5/31/18 9:12 p.m.
This is what I was told when they replaced my air conditioner last summer.
glueguy
glueguy Dork
6/1/18 6:29 a.m.
Yep, I'm in FL so it's lizards and insects.  Thank you!
spitfirebill
spitfirebill MegaDork
6/1/18 7:41 a.m.
Well to build on this a bit, I have a trap just off the air handler in the attic of a 2 story home.  Why would that be?  I don't think insects are going to make it that far and totally ignores the air handler in the crawl space.   That one doesn't have a trap.
SVreX
SVreX MegaDork
6/1/18 8:31 a.m.
It's an air seal for your condensate box. No trap is the same as drilling a hole in your ductwork.
HVAC traps and condensate explained
RossD
RossD MegaDork
6/1/18 8:32 a.m.
The static pressure from the fan would blow air right out the tube if it wasnt for a water trap with more inches of water than of static pressure. For a home furance, I would expect around 3/4" of water column from the fan and a safety margin in the condensate drain line.
spitfirebill
6/1/18 9:18 a.m.
In reply to SVreX and RossD :
Thanks.
HLWwc4yWaDDTgcqiUOYn9PhSVTzXSBAx1SfwCr5nlAqnIVrgRghu50D11kPAQv2S
