CamaroKeith
CamaroKeith Reader
12/15/12 10:11 a.m.
Unfortunately, not an auto upholstery question.....
I had a pipe burst in the kitchen and dumped a sink full of dirty dishwater on the couch below. Took the covers off the cushions and pillows and washed those - but how do I get the perceived nastiness out that soaked into cushions? Not sure going to town with a bottle of Resolve is the right answer so I thought I'd post it here.
Thanks, Keith
rebelgtp
rebelgtp UltraDork
12/15/12 10:38 a.m.
SWMBO worked many water damages and sometimes even with their huge truck mount sometimes furniture would still be a write off. The rig they used I swear had enough suction to pull an elephant through a garden hose.
alex
alex UltraDork
12/15/12 11:47 a.m.
I'd suggest power washing it and drying it in the garage (or outside) with a bunch of fans pointed at it, if that's all still feasible with the weather in MD.
Ojala
Ojala Reader
12/15/12 5:30 p.m.
I would replace the batting/foam that is in the cushions just because it is pretty cheap to buy at a sewing or craft store. It is also fairly easy to re-upholster most furniture if it is mostly straight lines. If you look underneath they are often held together with staples. Just pull a line of staples, insert batting or foam of your choice, and re-staple. The only place it can get tricky is on the arms or around complex compound curves.
CamaroKeith
CamaroKeith Reader
12/15/12 8:46 p.m.
The problem is, mine is not batting and foam - its foam and feathers.
BoxheadTim
BoxheadTim PowerDork
12/15/12 8:55 p.m.
The feathers are probably a write-off.
aKBHKqeMhx8mWoVgEoYHb5SwWaX1SuX7dTLATrKSdW1xsUXAcajsFu37qnv3IEJp
