ProDarwin
ProDarwin UltimaDork
2/1/20 4:30 p.m.
As of earlier today, my washing machine drum does not spin.  Its a top load whirlpool from circa 2001.
The lid switch has continuity when down.
When I put it on spin cycle, the machine runs, pump drains it, drum does not spin at all.
I hear no noise indicating the motor is trying to spin the drum.
Any suggestions?
Steve_Jones
Steve_Jones Reader
2/1/20 4:34 p.m.
Most of the time it's a broken belt.
ProDarwin
2/1/20 4:38 p.m.
Oh, forgot to mention this is not belt drive.  It looks like the motor is perpendicular to the spin axis and there is a transmission of some sort.
NOHOME MegaDork
2/1/20 4:39 p.m.
Mr_Asa
Mr_Asa Reader
2/1/20 4:40 p.m.
What model?
Indy-Guy
Indy-Guy PowerDork
2/1/20 4:43 p.m.
 Repair Clinic .com
Link
Type in model number and they have a diagnostic grid and AWESOME repair videos.
I've used them often to keep my old junk working
Slippery
Slippery UltraDork
2/1/20 5:11 p.m.
I had to change that coupling as well.
stanger_missle
stanger_missle UltraDork
2/1/20 6:27 p.m.
The older Kenmore washer in the house I'm renting did the same thing.
The motor coupler disentigrated. Since I'm renting, I called the property management who dispatched the appliance repair guy. He said that this is super common and replaced it with an upgraded part that had metal in it. It took him about 10 minutes.
Steve_Jones
Steve_Jones Reader
2/1/20 7:30 p.m.
Well then, probably not the belt :)
Robbie
Robbie MegaDork
2/1/20 7:47 p.m.
Do you have a BMW washing machine? Because that is a guibo.
ProDarwin
2/1/20 8:01 p.m.
Guibo thingy is fully intact.  It appears to be the upgraded part (center is metal).
Should I be able to spin the drum (slowly) by turning the transmission input by hand?  Or will that never work due to whatever the clutch system is?
The motor must be getting power as the the rear output of it is what drives the pump, so at this point I think it hsas to be something inside the transmission
ProDarwin
2/1/20 9:42 p.m.
Indy-Guy said:
 Repair Clinic .com
Link
Yeah I do like their guides.
I haven't used their diagnostic grid.  I can't find the part number on my washer anywhere :(
Related note:  There is some rust near the bleach tray in this and on the door.  Enough that bits are flaking off and falling into the drum.  Nothing structural, but its messy and I'd like to keep it from getting on my clothes.  Is this fixable with a wire brush and some paint, or is that going to be an extremely short term bandaid at best?  I can't imagine it would be nearly as effective as the factory powdercoat.
Slippery
Slippery UltraDork
2/1/20 9:55 p.m.
Did anything get jammed between the drum and shell?
ProDarwin
2/1/20 10:04 p.m.
Not that I know of, but I didn't separate the two to check.
My guess right now is the clutch.  But I can't seem to find any info on how to tell if it has gone bad.
I'm kinda hesitating pulling that apart right now and slowly talking myself into just replacing the thing.  The more I screw with it, the more the rust is bothering me.
jfryjfry
jfryjfry Dork
2/1/20 10:23 p.m.
How funny.  I JUST tore apart my washing machine to fix the rust and tackle a spin issue I have.
It took me most of the day, and the spin issue persists.
mine spins but is out of balance.  Even with nothing in there.
since I can't figure out what the problem is, I'm torn between just buying another one or spending more time and start putting money into it.
yours sounds fixable and I bet you can figure it out pretty quickly
Rufledt
Rufledt UberDork
2/3/20 8:43 a.m.
Replacing a clutch on that one is way easier than you think, I say go for it.  The coupler can be replaced at the same time.
Mr_Asa
Mr_Asa Reader
2/3/20 10:03 a.m.
ProDarwin said:
Indy-Guy said:
 Repair Clinic .com
Link
First picture here, with the door open.  Look inside, under the door at the edge of the hole that is covered by the door.
That's where Whirlpool likes to hide the model number.
FWIW, when mine stopped spinning it was the agitator mechanism.
ProDarwin
2/3/20 10:09 a.m.
Sunday morning I just said berkeley-it and bought a new one.  Such is life in a consumer society :(.  I had a big mental battle over it because I don't like to throw things in the trash, but I just didn't feel like dealing with it anymore.  I might fix the clutch and maybe sell it to someone for $50.  I don't plan on dealing with the rust.
Now I have one that dries clothes better (which is good because I rarely use the dryer), and does a load twice the size with half the water.
AngryCorvair
AngryCorvair MegaDork
2/3/20 10:55 a.m.
and you have many square feet of challenge sheetmetal!
jjSl0iztnQ8MHEynV5MUeHbjs2CJpfT0PDPRSA73btviiYVpK9nLcL51yMV9CGPq
