KyAllroad
KyAllroad UberDork
10/22/16 5:27 p.m.
So a few weeks ago I was cruising around harbor freight when I saw their pneumatic brake bleeder. I've struggled with bleeding brakes (find a person, push, twist, stop, twist, release, repeat infinite times) so I figured that 30 bucks would be a good investment.
This thing is awesome!!!! I bled the clutch and all 4 corners of the Miata in 10 minutes by myself. Then the Altima which was just as easy and took as long to drive up on the ramps as to bleed. Why o why have I been bleeding brakes the stupid way when this thing exists??
It's dinner time now but tomorrow the rest of the fleet may get a nice solid bleeding, I'm gonna be like a 1750's doctor and this thing is my leech! Whee!!!
wearymicrobe
wearymicrobe UltraDork
10/22/16 6:33 p.m.
Did you get the one that bolts on top of the master cylinder or the one that is like a little miti vac at the corners.
KyAllroad
KyAllroad UberDork
10/22/16 7:02 p.m.
Miti vac. I have 5 vehicles and none have even similar master cylinders.
paranoid_android74
paranoid_android74 SuperDork
10/22/16 8:02 p.m.
Whoah, I didn't know they sell one!
That's going on my list for sure
10/22/16 8:56 p.m.
I never got mine to work properly.
Brian
Brian MegaDork
10/22/16 9:19 p.m.
Duke wrote: I never got mine to work properly.
Same here. conventional way sucks.
Stefan (Not Bruce)
Stefan (Not Bruce) MegaDork
10/22/16 10:19 p.m.
I built my own pressure bleeder from an old master cylinder cap and a garden sprayer.
Cost all of $10 and I've done several cars with it.
http://www.ibmwr.org/ktech/pressure-bleeder/bleeder.shtml
I've tried the mityvac style units and they've not really worked for me.
DeadSkunk
DeadSkunk UberDork
10/23/16 7:26 a.m.
In reply to Stefan (Not Bruce):
I did the same thing and when I'm at the junkyard grab master cylinder caps.
Ian F
Ian F MegaDork
10/23/16 7:37 a.m.
This post sucks without links... this one?
KyAllroad
KyAllroad UberDork
10/23/16 8:10 a.m.
In reply to Ian F: Sorry, I suck at hotlinking. Yes, that's it exactly. Just stick the hose over the bleeder, crack it open with a wrench and pull the trigger. Magic occurs with the "Venturi effect" and sucking happens. Pulls the nasty old brake fluid right through.
10/23/16 9:53 a.m.
My HF bleeder always drew as much air in around the fittings as it did through the brake system.
Ian F
Ian F MegaDork
10/23/16 3:00 p.m.
In reply to KyAllroad:
There's that "chain-link" button right above the . Works well.
I have a cooling system vacuum filler that works the same way.
Ian F
Ian F MegaDork
10/23/16 3:02 p.m.
Duke wrote: My HF bleeder always drew as much air in around the fittings as it did trough the brake system.
I agree - I've tried to use my Mity-Vac for bleeding brakes and if the bleeder fitting doesn't thread tightly into the caliper or wheel cylinder, then it tends to suck more air than fluid.
vwcorvette
vwcorvette SuperDork
10/23/16 3:19 p.m.
I've used a Vacula for nearly 20 years. Works great. I have a bunch of diy attachments so I can suck fluid out of the master before pulling from the bleeders.
MulletTruck
MulletTruck Reader
10/23/16 6:05 p.m.
I usally put a Schroeder valve on the cap and use a couple psi to push it through
travellering
travellering Reader
10/23/16 7:30 p.m.
MulletTruck said: I usally put a Schroeder valve...
my valve? What's it look like?
Dr. Hess
Dr. Hess MegaDork
10/23/16 7:40 p.m.
Hey, us docs still use leaches. I've seen them used by plastic surgeons. So, put your "1750's" "ole-tyme" bull E36 M3 up. Them leaches are "modern medicine." y0.
I use a long piece of clear tubing (nasal cannula O2 tubing is PERFECT) and a jar. Never have a problem doing them myself.
mGYfFPksJnOq6rfCIHJEjlkkAWc54nKTjayM7Cq6DWPRAJhZ43AxzuNnsRYLKKjZ
