Cotton
Cotton Dork
3/29/12 3:35 p.m.
I was able to get a title for one of my cars through a company in Michigan (I'm in TN). There were a few requirements, like the vehicle needing to be pre 1985, but it worked out for me and the cost was $100 bucks. He also does motorcycles.
I knew the vehicle didn't have a title when I bought it, but it was cool enough and cheap enough to take the risk....worked out.
Grtechguy
Grtechguy PowerDork
3/29/12 4:00 p.m.
In Michigan, you can have the vin run by the Sheriff to see if it's stolen and then get a sign off
Donebrokeit
Donebrokeit Reader
3/29/12 4:17 p.m.
In reply to Cotton:
I know someone in need of this company do you have there info?
Thanks Paul B
16vCorey
16vCorey UberDork
3/29/12 4:21 p.m.
I've used its-titles.com many, many times with no problems what so ever.
rebelgtp
rebelgtp SuperDork
3/29/12 4:34 p.m.
Gearheadotaku wrote: I just want to hear more about this Regal Turbo T....
Its an 83 in primer. Appears to have an aftermarket sunroof sadly, though I have enough extra G bodies laying around to cut a patch from. In the add it says the turbo is missing from the engine, so that is a biggy. However I figure even if the engine is not salvageable I could go all out evil and build a twin turbo 411 Olds out of my diesel block and shove in it. I even have a 12 bolt rear from a GTO that would fit in the car to help handle putting down the power from that engine.
Cotton
Cotton Dork
3/29/12 4:59 p.m.
In reply to Donebrokeit:
sure just send me an e-mail. cottonyzf @gmail dot com and I will forward you all the info.
Also, this guy doesn't charge you until he has the title. He was great to deal with.
Ranger50
Ranger50 SuperDork
3/29/12 5:09 p.m.
Grtechguy wrote: In Michigan, you can have the vin run by the Sheriff to see if it's stolen and then get a sign off
Because MI isn't a compact state. Their search is only within MI borders. BTDT. Also, depending on the last "real" titled state of vehicular residence, you may or may not have title troubles when registering in the original state.
Pete240Z
Pete240Z UltraDork
3/30/12 8:12 p.m.
http://chicago.craigslist.org/nwc/cto/2865978725.html
Good luck getting a tile in Illinois.
novaderrik
novaderrik SuperDork
3/31/12 1:26 a.m.
how cheap is this car? i only ask because you can buy a running/driving 84 or 85 with the original drivetrain for $2k if you don't need it to be pretty and are willing to wait for one to pop up, and they are better in pretty much every way than the 83 model.. better suspension.. better rear end with better gears.. better engine with sequential multiport efi and distributorless ignition, 200-4r overdrive trans, a cleaner dash and interior layout...
rebelgtp
rebelgtp SuperDork
4/6/12 11:46 a.m.
An update. A friend in the area went to go check on the car for me and said it wasn't even worth the trip. Rear glass was smashed out, frame was rotted away and the entire turbo setup was gone.
JoeyM
JoeyM SuperDork
4/6/12 12:22 p.m.
Glad you didn't get suckered
rebelgtp
rebelgtp SuperDork
4/6/12 12:33 p.m.
I'm glad I at least had someone in the area that knew these cars to go check it out for me so I didn't have to waste a couple tanks of gas in the truck, that is a spendy proposition anymore.
Ah well the search continues...though as I think about it I keep thinking about that monster Olds motor I plan on building some day I am kinda thinking maybe it should go into a FE3X clone or something...
Z6Gik6T0ZVW9Ouo7AU9KzLKcFXCYTbpfBgpq8uu7lbOg7WIF05DcoAjmccDXkssp
