Pete240Z
Pete240Z UltraDork
4/27/12 10:58 a.m.
If this was on the way to work I bet it woke him up that day.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140742767502&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
jimbbski
jimbbski Reader
4/27/12 11:08 a.m.
Been there, done that. Well as least my friend was.
Happened alot back in the late 80's & early 90's with early strut cars from the 70's. Rust never spleeps!
N Sperlo
N Sperlo UberDork
4/27/12 11:08 a.m.
The picture is too huge and too detailed. Please post a smaller one.
MG Bryan
MG Bryan SuperDork
4/27/12 11:09 a.m.
The lower body cladding seems to have had a negative impact on the car as well.
Pete240Z
Pete240Z UltraDork
4/27/12 11:11 a.m.
If the engine was the other way it might make a cool locust starter.
Giant Purple Snorklewacker
Giant Purple Snorklewacker UltimaDork
4/27/12 11:13 a.m.
A little gum on that should fix it right up
N Sperlo
N Sperlo UberDork
4/27/12 11:36 a.m.
Giant Purple Snorklewacker wrote: A little gum on that should fix it right up
Oh, that was a "g..."
SVreX
SVreX UltimaDork
4/27/12 11:44 a.m.
Did it blow through the rear window?
Curmudgeon
Curmudgeon MegaDork
4/27/12 11:54 a.m.
Wonder if the final amount will cover some undies and pants? 'Cuz I'm going to venture that the ones the driver was wearing that AM are no longer wearable.
Ian F
Ian F UberDork
4/27/12 12:37 p.m.
SVreX wrote: Did it blow through the rear window?
Amazingly enough, it didn't.
Looks to me the high bid has already exceeded the value of the remains.
hotrodlarry
hotrodlarry HalfDork
4/27/12 9:53 p.m.
um.. wow.
wlkelley3
wlkelley3 Dork
4/27/12 9:58 p.m.
Not even enough metal to weld it back on!
mad_machine
mad_machine MegaDork
4/27/12 10:27 p.m.
I saw that with a Mk2 Jetta .. not to that extent.. but to where I could poke a finger THROUGH the strut tower's rust from the engine compartment into the wheel well.
Nitroracer
Nitroracer SuperDork
4/27/12 11:10 p.m.
I knew what the car was from just the first picture, I had one a few years ago. That is one of their biggest problem areas.
Mine wasn't that rusty, but it wasn't beautiful either. I actually saw three nicer ones in a local junkyard while I owned mine. Haven't seen any since.
iceracer
iceracer UltraDork
4/28/12 9:37 a.m.
I remember when SAAB 93's had that problem. Factory came out with a kit to fix it. No welding involved.
iceracer
iceracer UltraDork
4/28/12 9:39 a.m.
iceracer wrote: I remember when SAAB 93's had that problem. Factory came out with a kit to fix it. No welding involved.
I seen Rabbits do that.
fast_eddie_72
fast_eddie_72 SuperDork
4/28/12 11:02 a.m.
That's a new one on me. Never seen anything like it.
Streetwiseguy
Streetwiseguy SuperDork
4/28/12 5:48 p.m.
Saw a 2002 with the rear shock mount held in with perforated steel strapping and wood screws once.
Streetwiseguy
4/28/12 5:54 p.m.
I just bought another B13 Sentra from salvage, that is fine except for a small dent in the passengers door. If that ain't a powertrain donor, I don't know what is. I wonder if my truck driving buddy is headed through to the Cat plant anytime soon?
DoctorBlade
DoctorBlade Dork
4/28/12 6:26 p.m.
How would you even fix that, the OP's pic.
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
4/28/12 6:28 p.m.
You wouldn't.
This happens to Escorts as well. Fixing it is never pretty. Once they blow completely like that you're pretty well boned.
patgizz
patgizz UltraDork
4/28/12 8:09 p.m.
caravans love to do that up front. they rot bad up here.
roll cage with built in upper strut mounts will fix it right up.
Taiden
Taiden SuperDork
4/28/12 8:11 p.m.
Saw it and was like... NX2000!!!!!!!!!!!!
Well, it's pretty obvious now, so I dont get any brownie points.
Taiden
Taiden SuperDork
4/28/12 8:14 p.m.
also the nx2000 has all the factory go fast parts for a 1.6L to 2.0L swap for a little four door sentra
bigger front brakes
rear disks
larger radiator
larger master cylinder
bigger motor and everything to go with it
wider lighter wheels
lower nx2000 seat rails
larger stock exhaust
and probably other things that im forgetting
So $600 for all that isn't really a bad deal considering you get to crush it after
mad_machine
4/28/12 8:15 p.m.
shame.. always thought the NX2000 was pretty.. almost bought one a dozen years ago
JnT4reZXfMilHTg55c8uzLq3It762pTF46Pmex0EUedHpXtBDdP5p3WynwhdUGiS
