Gearheadotaku
Gearheadotaku PowerDork
11/23/15 6:37 p.m.
my windows and door wall are fairly drafty, so I installed the plastic heat shrink stuff for the winter. Drafts are gon, but now I have condesatin forming on the plastic and dripping onto the carpet and wood sills. Suggestions? mopping with a towel 3 times a day isn't realistic.
Toyman01
Toyman01 MegaDork
11/23/15 6:55 p.m.
A small bag of rice? A sock full works for cars.
That is assuming it's forming on the inside of the plastic.
Woody
Woody MegaDork
11/23/15 8:07 p.m.
I did that in an apartment one winter. I also kept the curtains closed all the time. By spring, it was covered with mold.
iceracer
iceracer PowerDork
11/24/15 10:31 a.m.
Small hole for ventilation.
Gearheadotaku
11/24/15 9:53 p.m.
the water is on the warm air side, not the cold. Vent hole won't help.
Hal
Hal SuperDork
11/25/15 3:43 p.m.
Get a meter to check the indoor humidity. Sounds like it is too humid in the house. Indoor relative humidity should be ~50%.
If humidity is OK, then you have too much cold air leaking thru the windows and filling the space between the window and the plastic. Only way I know to fix that is tape up the edges of the windows on the outside.
Fueled by Caffeine
Fueled by Caffeine MegaDork
11/25/15 7:55 p.m.
I got old single pane windows in my rental. Yup. Condensation.
TRoglodyte
TRoglodyte SuperDork
11/25/15 8:13 p.m.
Put the plastic outside?
skierd
skierd SuperDork
11/26/15 4:01 p.m.
Dehumidifier and or ventilation. Keep the inside humidity around 45% and you'll be fine. My house is extremely well insulated and we get floods of condensation starting around 55%, so I run the HRV till it dries out.
Gearheadotaku
11/26/15 8:17 p.m.
Good idea on the humidity meter, I'll check into that.
DzjbpJug1jXtlxiXQAELrgCH2eXYMn66xAt9Csgqd7hgjMnLna66QS4Sk8uot1xd
