So my house/pile project is moving along and I'm starting to think that I should work with my electrician on the project to get some additions made while walls are still open and there's not more pile of house in the way. Here's what I'm thinking about doing with home theater;
Wall mount TV with an HDMI cable running down from the TV to the HT receiver below it (via in-wall conduit) and a coax cable running up to the attic for eventual connection to an antenna. Power also behind TV. Finally behind TV is an Ethernet wall jack with cable running over to network switch (discussed later).
Behind the HT reciever are the following jacks in a pair of wall plates; "speaker plate" with a pair of RCA jacks with cable running to a corner of the room where a subwoofer will live, and a pair of banana jacks with cable running to a plate straight across from the TV so rear fill speakers can be mounted on either sides of a couch opposite the TV. There's also a "data plate" behind the reciever with two jacks for Ethernet runs to the network switch, an HDMI jack with cable running up to the TV (so the theater is doing all HDMI switching and related signal intake), and a coax running up to that same attic antenna for FM reception (as well as possible splitting again for OTA TV recording if I decide to do that at some point in the future, seems doubtful)
For Ethernet/networking, there's the mentioned three runs going from the TV and whatever I drop into the HT components pile, and then two jacks each in the smaller two bedrooms. One bedroom is planned to be an office room with a computer or two, and then two in the other bedroom for general flexibility. All of these runs will terminate in the basement, probably at a gang box with a real wall plate for neatness, going to a 16-port switch with whatever router/modem from the internet service I eventually end up with. I'm suggesting a 16 port because they seem cheaper than 12-port models based in about a minute of searching and eight ports isn't enough when considering the cable running to the modem/router. I will have wifi in the house but for items that aren't really mobile and should be there long-term I would prefer the hardwire.
I'm planning on buying all of the plates and ports/connections from Monoprice as well as the cable. They seem to have good selection for Keystone-style snap-in ports and I can get everything at one place this way. I was planning on using 14ga speaker wire from them as well.
What am I missing? Do I need anything else running to the TV? I really don't plan on going with cable TV. The two Ethernet runs to the HT reciever area are for a game console I don't currently own (and no serious plans for one at this time, but maybe later) and a home theater / emulator PC that I do have more solid plans for.
Thanks, GRM Borg, for your assistance!
