garethashenden
garethashenden New Reader
4/12/22 7:42 p.m.
I'm about to embark on rebuilding the carbs on a friend's motorcycle. I have a small ultrasonic cleaner that will fit a whole carb in it. The plan is to put the whole thing in, and then do it again once its disassembled. But I have no idea what the best fluid to use is. What would you recommend?
Mr_Asa
Mr_Asa PowerDork
4/12/22 8:39 p.m.
Gasoline works great.  I usually put the gas in a gallon paint can, then fill the outside with water.
wearymicrobe
wearymicrobe PowerDork
4/12/22 9:21 p.m.
Honestly I just use water, heated as hot as you can get it. Disassemble down to small enough parts to fit and hit them as hard as you can.
I find that you need to use compressed air to blow out the all the holes and then drop them in again. Then repeat until the water stays clean after a five minute cleaning cycle.
I have never gotten a carburetor as clean as I can with the sonicator. I will not do it any other way now.
I have tried a medical cell pulverizor sonicator once in the past and that was amazing. One cleaning was all it took and it stippled everything out of that carb.
ClemSparks
ClemSparks UltimaDork
4/12/22 10:25 p.m.
I did a lot of checking into this years ago.  I've forgotten a lot of it but prevailing wisdom was not to use a solvent (though, I bet it would work well).  You want something safe for aluminum which presents a challenge.
I believe I decided that thinned-down Simple Green was a good choice that was safe for aluminum and was able to be easily disposed of.  Please verify both of those things as I may be remembering wrong.
I was really looking for something I could safely pour down a drain when I was done.  That may not be a concern for everyone.
cabbagecop
cabbagecop Reader
4/13/22 6:26 p.m.
I use Extreme Simple Green for aircraft and water  in my ultrasonic and have had good results so far. I agree that the hotter the better for cleaning.
Mr_Asa
Mr_Asa PowerDork
4/13/22 7:34 p.m.
Simple Green can damage aluminum, but it will take a while. https://simplegreen.com/faqs/15/
Stay the hell away from Purple Power, that stuff takes no time at all to damage Al
ClemSparks
4/13/22 9:07 p.m.
There was a product called "Alconox" that sent me some samples of their aluminum-safe cleaner.  If I was doing it regularly or commercially I would likely lean toward that.  I'm not sure if it's available outside of industrial outlets/quantities.
Cousin_Eddie (Forum Supporter)
Cousin_Eddie (Forum Supporter) Dork
11/24/22 5:10 p.m.
wheelrush0 said:
Ultrasonic cleaner is best way to remove crab but using a best solution is also important, i found best ultrasonic solution form this post, I think it can help you also. Read Here
First post on this board and a shady link included. Feels like one of those little boat things.
11/24/22 6:18 p.m.
In reply to Cousin_Eddie (Forum Supporter) :
*cough* canoe *cough*
californiamilleghia
californiamilleghia UltraDork
11/24/22 8:57 p.m.
Since many carbs are made from zinc die cast , do you use the same cleaning solutions when you ultrasonic clean them as you would with aluminum?
11/24/22 9:28 p.m.
I do. I have a very powerful ultrasonic cleaner and I use greatly diluted Simple Green on bad carburetors. The results are stunning.
V1wu7T5z36WeqbUcJCEvxQRbpmFwCbz5dYGy8PPFI2ZYyXRfFkE4941HuDLqtIhV
