MyMiatas
MyMiatas HalfDork
9/12/23 10:52 p.m.
MyMiatas said:
In reply to Slippery :
Where did you get that neat green bag from??
If anyone else wanted to know where this bag came from....... https://officialtoolroll.com/collections/all-products
Nice deal for three.
Slippery
Slippery PowerDork
9/12/23 11:47 p.m.
Sorry I never replied, just saw this now.
Yes! That's where I got it from. Its very well made and it holds a whole lot of tools while keeping them organized.
DarkMonohue
DarkMonohue Dork
9/13/23 12:24 a.m.
Some form of lubrication other than WD40 might be a good idea. Maybe a little bottle of 3-in-1 oil. If you know anybody on the vape, see if you can get an old plastic refill bottle from them. They make great micro oilers if you fill them with the lubricant of your choice. I usually like ATF, but use whatever you like.
A tube of Chapstick also makes a pretty good light-duty grease stick and gasket dressing.
A dozen round toothpicks might come in handy in the event you either drill a screw hole one size too large or diwcover it has been stripped out by over torquing. Wood glue is optional.
Small tubes of Gorilla Glue and/or CA (Super Glue) are handy. Keep the CA in the fridge or freezer, not in the bag, until you head out.
Keeping a spare 20A circuit breaker to fit your panel pretty well guarantees that you will never need it.
A small selection of wirenuts would be smart, and maybe have spare outlets  (normal and GFCI style) and light switch in case you get a call for electrical repair.
Maybe a tube of drywall hole filler would be useful. Or maybe drywall repair and refinishing goes into a separate, dedicated bag.
I have a talent for turning a 25-pound "go bag" into a 150-pound soft sided roll cab. Take all of this with a grain of salt and apply discretion.
BoscoRamos
BoscoRamos New Reader
9/20/23 11:30 a.m.
For me, my tools include stuff mainly for emergencies like:
  • 1/2" and 3/4" Shark bite fittings with valves fitted to them
  • assorted pex fittings, adapters, valves, crimpers, pipe cutters, etc.
  • scraps of copper pipe, valves, emory cloth, flux, and solder
  • tubing cutter/pipe reamer
  • insulated screw drivers
  • linesman pliers
  • Wire strippers
  • A few receptacles, switches, spare breakers, wago's/wire nuts, electrical tape, pull twine, zip ties, cable staples, and 3 foot wire scraps (14/3, 14/2, 12/2, 10/3)
  • Various machine screws and lumber fasteners
  • Ethernet crimpers, coax compressors, coax strippers
  • Basin wrench
  • Pipe wrenches (at least two)
  • Slip joint pliers in various sizes (including massive ones to replace water heater gas valves)
  • Pipe dope
  • Teflon tape for water plumbing and for gas
  • Duct tape
  • Foil duct tape
  • Sheet metal/tin snips
  • Hammer
  • Multimeter
  • Receptacle tester
  • SAE sockets in 1/4" and 3/8" drive
  • Adjustable wrenches from tiny to extra medium
  • Cordless impact, cordless right angle drill, cordless jig saw, cordless recip saw, and cordless heat gun (for any frozen pipes)
  • Bit set
  • Various hole saws and speedbor-type bits
  • Jab saw + putty knives
  • Headlamp w/extra batteries
  • Goggles (because I never seem to need them until I'm on my way to the ER)
  • Work gloves
A lot of that sounds extra, but my bucket of tools has rarely let me down and saved me from quite a few after hours disasters.
Ian F (Forum Supporter)
9/20/23 11:39 a.m.
When I was living in an apartment a few years ago, I brought a few tools from home but also ended up buying a few at Lowes Depot to do some small DIY furniture projects.  One of them was a Japanese pull saw.
procainestart
procainestart SuperDork
9/20/23 12:08 p.m.
This thread is costing me money, in a good way.
Tangential question: cat's paw with "dimpler" to bang down around the nailhead: gimmick or genius?
DarkMonohue
DarkMonohue Dork
9/20/23 12:27 p.m.
This bag is on sale (coupon required) right now at Hazard Fraught. Looks like a no-brainer for ten bucks.
EDIT: After reading some reviews, sorting by lowest rating first, it looks like this one may be too flimsy to be viable.
ProDarwin
ProDarwin MegaDork
9/20/23 1:40 p.m.
Sorry for blurry pics.
I added a fabric strap on either side of the bag so I can hook the drill & driver to the outside of the bag, leaving space on the inside for other stuff.  They should make this standard on these bags (and make them about 1" taller  - occasionally when I set it down its enough to unhook one of them.
dxman92
dxman92 SuperDork
9/21/23 1:40 a.m.
I keep a small black canvas bag from HF in the back of my car. It has vice grips, Lowe's multiple pliers set, multibit screwdriver, duct tape, electrical tape, zipties, work light, disposable paint respirator and a couple other things I can't recall right now.
Panhandler
Panhandler New Reader
9/27/23 7:09 a.m.
Flash light
SV reX
SV reX MegaDork
9/27/23 8:59 a.m.
Gimmick.
In 45 years in construction, I can't think of a single time I ever would have needed or wanted that.
J8NYmNpg6tTITgecsGr5fshPQui2I5OCWh4RuKr0PtAeW7p2mdGRrOdhcHsOQhrO
