3 4 5 6 7
AtticusTurbo27
AtticusTurbo27 Reader
11/20/13 8:52 p.m.
In reply to failboat:
I'll test it out now. In the mean time, All the other cars are done. The Hyundai is probably my favorite to drive honestly. I'm really happy with how it turned out. The updated specs are on the front page now and i'll include them in the post below.
You can get all the setups off my storefront (AtticusTurbo27)
AtticusTurbo27
11/20/13 8:53 p.m.
Current B Spec line up as follows:
Mazda 2 (C352)
115hp, 1,981lbs.
Weight/Power Ratio: 17.22:1
Street Air Filter, Sport Exhaust, Race Flywheel, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Sport Weight Reduction, Street Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 front and rear, Spec Enkei RPF1's in stock size. Updated: (11/20/12)
Nissan Versa (C362)
122hp, 2,357lbs
Weight/Power Ratio: 19.32:1
Race Flywheel, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Sport Drivetrain, Race Diff, Race Compound Tires in 205 front and rear, Spec Enkei RPF1's in stock size. Updated: (11/20/12)
Toyota Yaris S (C351)
106hp, 2,207lbs
Weight/Power Ratio: 20.82:1
Stock Engine, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Sport Weight Reduction, Sport Drivetrain, Race Diff, Race Compound Tires in 205 front and rear, Spec Enkei RPF1's in stock size. Updated: (11/20/12)
Ford Fiesta (D337)
118hp, 2,126lbs
Weight/Power Ratio: 18.02:1
Stock Engine, Sport Brakes, Sport Suspension, Race Sways, Race Cage, NO Weight Reduction, Race Diff, Race Compound Tires in 205 front and rear, Spec Enkei RPF1s in stock size. Updated: (11/20/12)
Honda Fit (C357)
125hp, 2,219lbs
Weight/Power Ratio: 17.75:1
Street Air Filter, Sport Oil and Cooling, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Street Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 front and rear, Spec Enkei RPF1's in stock size. Updated: (11/20/12)
Kia Cee'D (Rio)(C359)
161hp, 2,590lbs
Weight/Power Ratio: 16.09:1
Race Air Filter, Street Ignition, Race Exhaust, Race Oil and Cooling, Sport Flywheel, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Sport Weight Reduction, Race Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 215 (stock) front and rear, Spec Enkei RPF1's in stock size. Updated: (11/21/12)
NEW!
Hyundai ix20 (C368)
141hp 2,299lbs
Weight/Power Ratio: 16.30:1
Sport Air Filter, Race Intake, Street Ignition, Race Exhaust, Street Cams, Sport Oil and Cooling, Race Flywheel, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Street Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 (stock) front and rear. Spec Enkei RPF1's in stock size. Updated: (11/20/12)
Suzuki Liana (C369)
147hp 2,189lbs
Weight/Power Ratio: 14.89:1
Sport Air Filter, Race Exhaust, Sport Cams, Street Oil and Cooling, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Street Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 front and rear. Spec Enkei RPF1's in stock size. Updated: (11/20/12)
VW Fox (C368)
123hp 2,060lbs
Weight/Power Ratio: 16.75:1
Race Air Filter, Race Exhaust, Race Cams, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 front and rear. Spec Enkei RPF1's in 15 INCH size. Updated: (11/20/12)
Scion xD (C365)
133hp 2,265lbs
Weight/Power Ratio: 17.03
Street Exhaust, Race Flywheel, Sport Brakes, Sport Suspension, Race Sways, Race Cage, Race Weight Reduction, Race Clutch, Street Transmission, Race Drivetrain, Race Diff, Race Compound Tires in 205 front and rear. Spec Enkei RPF1's in stock size. Updated: (11/20/12)
AtticusTurbo27
11/20/13 9:19 p.m.
NEW!
Suzuki Liana (C369)
147hp 2,189lbs
AtticusTurbo27
11/20/13 9:47 p.m.
NEW!
VW Fox (C368)
123hp 2,060lbs
AtticusTurbo27
11/20/13 10:10 p.m.
NEW!
Scion xD (C365)
133hp 2,265lbs
DukeOfUndersteer
DukeOfUndersteer UltimaDork
11/21/13 8:02 a.m.
For those who didn't see my post on Facebook, I got banned from Turn 10 for the "Bag of Dicks" sticker I made for Poopshovel. It's not permanent, just for a week. I still have the capability of racing online, just can't buy stickers and cars online... hahaha.
failboat
failboat SuperDork
11/21/13 8:14 a.m.
Wow. You can pretty much do whatever you want on Forza. but as soon as you upload a photo of it, its out there for the self policing community of fanboys to see and report to T10.
mutant
mutant New Reader
11/21/13 11:07 a.m.
atticus-thanks for your hard work on the cars-looks like this is gonna be a blast!
AtticusTurbo27
11/21/13 12:40 p.m.
No problem. I kinda have the hang of it now and it was pretty easy to add the extra cars. When running a spec 205 the grip is pretty even across all the cars. I used the benchmark data of the lateral G's to make sure they were all around 1.05 lateral G's at 60mph. Then bumped the power until the car is around 125-130mph top speed. Then go test. Usually the cars are close within a few hp, so I would either add or subtract around 5 hp for 2 or 3 tenths. Then for a single tenth i would drop or add 5-10 lbs of ballast, or upgrade the clutch or transmission for slightly faster shifts. I got to the point where i could guesstimate, then go test and the car would usually be within a half second of where I would like it to be, then i'd do some adjustments to speed up or slow it down then test again and usually be within a tenth, then do a last tweak and be on.
After so many laps, I can pretty much feel after turn 1 if the car is too fast or too slow. But I'm fairly confident they are about as close as they can be to each other. No car really handles better or is faster in a straight line. I'll add the lbs per hp ratio to each car's info as well.
Lancer007
Lancer007 Reader
11/21/13 12:41 p.m.
In reply to DukeOfUndersteer:
Can he still use the sticker? Haha
AtticusTurbo27
11/21/13 12:51 p.m.
So all the cars are within 5 lbs per hp. I figure that variance is due to gearing overall weight and torque of the engines.
DukeOfUndersteer
11/21/13 1:18 p.m.
Lancer007 wrote: In reply to DukeOfUndersteer: Can he still use the sticker? Haha
HAHAHA
mutant
mutant New Reader
11/21/13 1:54 p.m.
i would like #171... car choice still pending...
are any of the assists going to be allowed( i.e. brake line abs ect,,,)
i may be getting a few of my friends from my new club to run-we will see!
poopshovel
poopshovel MegaDork
11/21/13 2:10 p.m.
HAHAHA
BETCHA THE berkeley I CAN! Dude, that sucks. I owe you a beer.
DukeOfUndersteer
11/21/13 2:39 p.m.
In reply to poopshovel:
Haha, it's cool. I got a couple cases from the boss.
LainfordExpress
LainfordExpress HalfDork
11/21/13 4:45 p.m.
I was all in for the Fit, but I'm going to have to try that VW out before I lock it in.
racerfink
racerfink SuperDork
11/21/13 6:16 p.m.
On your listing for the Kia C'eed, I think you mean Street Transmission, instead of Race Transmission.
AtticusTurbo27
11/21/13 7:57 p.m.
In reply to racerfink:
Haha yeah thanks! I knew I'd mix something up!
On now if anyone wants to join in for some testing!
DukeOfUndersteer
11/23/13 11:21 a.m.
Think I'll be getting on after F1 quali.
Redline
Redline New Reader
11/23/13 11:56 a.m.
Redline 0729, formerly Switchblade762 is IN!
The Green Coast Pharmacy Kia is ready to race!
In order to get this photo, it took some fast work. Photo, upload to Storefront, go online to Forza.net, download photo, get back to xbox and delete from SF before some enema nozzle complained and whined
failboat
failboat SuperDork
11/23/13 12:22 p.m.
I am busy running errands and hanging out with the wife today, but i should still be in for tomorrow night's practice session.
Redline
Redline New Reader
11/23/13 1:56 p.m.
Been testing both the Green Coast Kia, and the Smirnoff Ice gold iX20 are both fast around Sunset. The little iX is quicker through the corners with slightly better handling, but the Kia gets out of the corners faster and down the straights faster. The Kia gets to 119 before T1, and the iX is hitting 117 at T1. That slight advantage gives the Kia a 1.07 better laptime. Could be I have more seat time, but I know in FGC's 2200#, 200hp lobby that little iX kills technical tracks better. What time Sunday night?(Central here)
Lancer007
Lancer007 Reader
11/23/13 2:49 p.m.
I'm watching quali on the dvr now, I might be on in half an hour unless the woman wants to watch the U of A game.
Redline
Redline New Reader
11/23/13 5:34 p.m.
I just built a Scion Racing xD and put it in the team garage. It goes fine, handles good, but I'm still faster in the Kia. Drive it like ya stole it!
Redline
Redline New Reader
11/23/13 5:39 p.m.
AtticusTurbo27 wrote: AtticusTurbo27 poopShovel DukeOfUndersteer Anti-Stance RacerFink failboat Lancer007 szeis4cookie t25torx (SAABBoy) LainfordExpress Mutant moparman76_69 clutchsmoke friedgreencorrado Pending: N Sperlo RoadRaceDart
Season 2, not enough space for a dedicated racer? If I got to be a provisional, I suppose that will have to do. No 7 ain't gonna like sitting any racing out though!
3 4 5 6 7
N3FtC7lNfLHhmtjHqXHMbJo0sbsTjqPVqMggnjiPfGtxTZ69apNU4qOf6BjwkR3N
