Grtechguy
Grtechguy SuperDork
3/3/12 2:45 p.m.
250cc 2-smoke should start with this correct?
150psi came on 3rd (40, 100, 150 approx when kicking)
Ranger50
Ranger50 SuperDork
3/3/12 3:29 p.m.
Unless it's flooded out/fouled plug, I would think.
44Dwarf
44Dwarf Dork
3/3/12 6:00 p.m.
only missing fuel and proper timing of spark
drmike
drmike Reader
3/3/12 8:56 p.m.
So true. I had an 80's Husky once that was hell to start, and it turned out it was a total piece of cra- uh, I mean, the ignition timing was way, way off.
44Dwarf
44Dwarf Dork
3/4/12 6:37 a.m.
I've bought a ton of 2 stroke that guys said "it ran great the last ride i was flying then it would not restart the next day" sheared the flywheel key when they hamered a big jump or log etc. $2.00 fix.
44
Grtechguy
Grtechguy SuperDork
3/4/12 11:49 a.m.
well this is a 78 IT250. here's to hoping that it's just a mildly dirty carb
HappyAndy
HappyAndy Dork
3/4/12 9:15 p.m.
If it has reed valves check for a bad one. It will still have compression with a bad reed, but you won't get a good air/fuel charge to the combustion chamber. IDK if a '78 yamie IT is reed or piston port induction, but reeds were showing up on a lot of Jap MX bikes by that time.
aussiesmg
aussiesmg SuperDork
3/5/12 8:10 a.m.
Bugger off canoe!
l4xvrpThDZdQifHyq2wpQAjdSbN6ZD4g9z2tigmWpuqhBhqbjKd3iLL2upc3wqMV
